To lock or not to lock the front. - JeepForum.com
post #1 of 17 Old 04-06-2009, 06:09 PM Thread Starter
bjl95mustang
bjl95mustang's Avatar
So I found a guy selling a dana 30 lock right for a steal.
I have an aussie in the rear.
I only use 4wd off road and I can't remember the last time I used it on the road. This is my dailey driver
From what I can find online a locker in the front is fine as long as i keep it in 2wd.
Any more I should know?
Thanks
ZJ 98 5.2 LIMITED De-Badged
4.5" Lift: RE 4.5" springs,Iro rear 3.5 springs+1" spacer, RE shocks, All adjustable arms, IRO front track bar and HD bracket, Rear jks track bar, 1-Ton Steering, 242 tc, 33x12.5x15 GoodYear wrangler silent tires, 15" rock crawler rims, Aussie Locker For My 44A, 760X u-joint front axles.
Soon to come Lock Right Front Locker.
Jeep Inferno member #10
Texas Jeep Club Member #78
bjl95mustang is offline
post #2 of 17 Old 04-06-2009, 06:41 PM
xJoshxx
2012 WK
Locking the front will not like turns..
use something like a Detroit True-Trac It's and LSD that doesnt use clutches and doesn't require any Special Diff fluids. And it's seemless from what ive heard. you wont notice it unless u take turns at like 432423 miles sharp.
locking the front wont have anything to do with it being 4wd 2wd Locking Means Both Wheels Spin at the same rate. meaning turning is horrible due to 1 tire has to spin slower than the other to perform a turn.
Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 ORA2 sold
2012 WK2 SRT8 - Current
99 WJ Limited Lifted.
2001 WJ stock 4.0 304k miles
xJoshxx is offline
post #3 of 17 Old 04-06-2009, 06:44 PM
shdybrady19
i have read alot of threads about tihs and locking the front isnt too bad on the streets
1996 5.2 orvis: 6" lift, 33x12.50's, 8.8 rear, t-case skid, gas tank skid, 242
Originally Posted by nick62087 View Post
If you can weld and aren't afraid to take a chance, I'd say try it - someone's gotta do it.
LOOKING FOR 96-98 ZJ CARPET, TAN OR BLACK IN COLOR, ALSO LOOKING FOR HOOD HINGES. 93-95 MIGHT BE COMPATIBLE
shdybrady19 is offline
post #4 of 17 Old 04-06-2009, 07:32 PM
comptiger5000
Josh - With a lunchbox locker, they only lock when power is applied. Therefore, in 2wd, they are just spinning and act as an open diff. When you put it in 4wd, you get a locked front.
comptiger5000 is offline
post #5 of 17 Old 04-06-2009, 07:41 PM Thread Starter
bjl95mustang
Man, It's hard trying to deciede what to do. It's like half say one thing and the other half say the other.
post #6 of 17 Old 04-06-2009, 08:53 PM
sadass
you should let me buy it. Problem solved!
5NineZJ,35mtr/k IRO 7" LA F/R Detroit F/HP-4.56 R/Aussie 44A. ARB Snorkel/JRC Sliders/ Protofab w/9500S./Bushwhackers. Novak242 TCcable.
sadass is offline
post #7 of 17 Old 04-06-2009, 08:58 PM
Bama_WJ
Bama_WJ's Avatar
A buddy of mine installed a lunchbox style locker in his D30 here recently. He has the 242 transfer case just like you do. Its not that noticable on the road with the transfer case in 2wd. Other than the clicking going around turns, its on road manners in 2wd are not bad. He loves it off road.
Daniel
Current Stable: 2001 WJ, 2006 WK, 2006 TJ
Bama_WJ is offline
post #8 of 17 Old 04-06-2009, 10:59 PM
rmtomasin
yeah i had a friend with a 4 runner who had that lunchbox style locker up front and it was all good it just makes a like ratchet clicking noise in turns but wasn't very noticable, i've been wanting one on mine
-Ryan-
Built Not Bought #233
98 ZJ I6
rmtomasin is offline
post #9 of 17 Old 04-07-2009, 12:44 AM
johnnycrash
I can attest to this, i have a loc-right up front, in 2wd wouldnt even know its there and you can faintly hear it when cornering, but you have to listen for it. if you go 4x4 on ashphalt you will know its there when you turn and step on the gas!!! she will only wanna go straight, and it increases torque steer, but only in 4x4,. other than that its invisible......
johnnycrash is offline
post #10 of 17 Old 04-07-2009, 01:08 AM
rustynail
LOCK IT!!!! If it's a deal go for it. 1 locker = 70% increase in traction over open diffs. 2 lockers = 100% increase
This will put a lot of strain on the front axle though. If it were me I would lock both with lunchboxes to even things out.
- Russ
5.9 ORVIS 33x12.5 MTR-Kevlar, 7" fr adj IR LA's, 7" rr adj RE SF SA's, adj JKS TB's, RE SB disc, RE Springs, JKS ACOS, 13" RS9000XL's, OME SS, NP231, Durango box, IR Sliders, IR Skid, 3" Flowmaster 70, K&N, Superwinch EPi9.0, Optima Yel, 2 air comp, Alpine, Garmin, Sunroof
rustynail is offline
post #11 of 17 Old 04-07-2009, 02:11 AM
sandman
i say do it, in 2wd you will barley notice it.
1993 Jeep ZJ. 4.0
sandman is offline
post #12 of 17 Old 04-07-2009, 02:59 AM
sadass
Come on guys don't encourage him.
I want him to sell it to me. Please let me know before Wednesday so I can save some Coin on my order..
If you wheel ,Do it Do it, put it in. You will have to remove the carrier this time for the d30, Just an extra couple of steps though. plenty of write ups on it though.
sadass is offline
post #13 of 17 Old 04-07-2009, 06:42 AM
blovingier
blovingier's Avatar
If only you had locking hubs, you wouldn't have any problems at all. I wish they made a conversion kit. I guess I'll just have to save up for a new axle with locking hubs.
"GRITZ"
99 Jeep Grand Cherokee Laredo - Totalled
-3" lift w/Bilsteins - - - - - - - - - - - - - - - - - -30.5" Pirelli Scorpion ATRs
07 Compass (wife's ride)Sold
-Stock
blovingier is offline
post #14 of 17 Old 04-07-2009, 07:22 AM
rugermack
Mile Marker and Warn both make unlocking hub kits, and there are others, only problem is it costs money and you usually loose your ABS braking due to no tone ring on new outer axle shafts.
95' Jeep Grand Cherokee Laredo, 148k, 5.2, NP242, 46RH, 4" RC lift, all new adjustable ca's(2 IRO front uppers and the rest RC adjustables), nitro shocks, JKS TB's, Jet Chip, Dynamax cat back, Magnaflow cat, GTP hood vents. 31" Pro Comps with Rock Krawler "D"s. Westin brush/grill guard with Hella 500s, 411's, Solid diff covers, detroit locker rear, power lock in front, SYE and Tom Wood's front/rear shafts, RE discos, BPE's, d-rings front and back, factory tc and rad skid, hitch, Sliders next.
03' Jeep Grand Cherokee Laredo, (wifes Jeep) 99k, 4.7 5 speed auto, K&N, KYB shocks, drilled-slotted rotors, All the toys.
2000' Ford Superduty, F250, 7.3, 198K, 37's, too much to list.
Built Not Bought #257
Parts for sale d30 and d35 parts
rugermack is offline
post #15 of 17 Old 04-07-2009, 07:23 AM
Steve98
Warn sells a lockout conversion kit for the 30, but it costs close to a grand. I have a trutrac and really like it, but if I did it all again, I would go selectable. Having very limited steering in 4x4 would suck to me, even though its a good deal.
2006 LJ Rubicon
Steve98 is offline
Power door lock motors work but no lock! lasvegas ZJ Grand Cherokee Forum 2 10-25-2009 12:29 PM
ignition lock wheel lock disengage ouikikazz ZJ Grand Cherokee Forum 1 08-20-2009 02:56 PM
Power Door Lock Buzz / Door Lock Duck Noise - Power Door Lock Actuator Solution Coppell-Jeep ZJ Grand Cherokee Forum 4 01-11-2006 10:25 PM
Rear hatch lock doesn't lock ltrains ZJ Grand Cherokee Forum 3 11-09-2005 03:54 PM
Anyone using (Wheel lock) Master Lock Tatinium or Club ??? Webb ZJ Grand Cherokee Forum 5 06-04-2003 08:15 AM
