Location of ABS Computer in 97 GC? - JeepForum.com
post #1 of 3 Old 04-03-2004, 09:48 AM Thread Starter
sntaday
I am looking for the ABS controller module in my 97 Jeep Grand Cherokee. I thought it was by the air filter. Thanks for your help!
sntaday is offline
post #2 of 3 Old 04-05-2004, 12:16 AM
ZJGuido
Junior Member
ZJGuido's Avatar
I can help you with this 'cause i recently had to change my ABS controller. The ABS controller and the ABS hydraulic pump are all one unit. This unit is located behind the air filter and in front of the master cylinder. You will be able to see the top of the pump but you wont be able to see the actual ABS controller 'cause its under the pump. To identify the unit, look for a cylinder-type shape that is screwed to what looks like a block and to the left of it you'll see a harness with a connecter that plugs into the block. You'll know what I'm talkin about when you take a look under the hood.
The downside is if you have to change the pump or the computer, you'll have to replace the whole unit.
Hope I helped!!
1998 Platinum ZJ 5.9 Limited
K&N FIPK / MOPAR ECU / Bilstein Shocks / H&R springs / Addco sway bars
ZJGuido is offline
post #3 of 3 Old 04-05-2004, 10:46 AM Thread Starter
sntaday
Thanks, ZJGuido
I found a used part on eBay. Hopefully, I will be able to install this myself, as long as nothing other than just replacing it needs to be done.
Hopefully, it will be a slam dunk.
sntaday is offline
Sensor goes off, sends signal to computer, computer sends it to my odometer... ef1992 ZJ Grand Cherokee Forum 2 07-20-2009 02:33 AM
location of engine computer 2003 g-Cherokee garye5007 ZJ Grand Cherokee Forum 3 11-04-2008 05:23 AM
Re-set computer tobogan ZJ Grand Cherokee Forum 7 04-17-2008 02:02 PM
MPG computer RFisher WK Grand Cherokee & XK Commander Forum 5 02-28-2008 01:48 AM
Computer MPG gregoryc. ZJ Grand Cherokee Forum 4 12-20-2004 02:30 PM
