Locating a problem with the heated seats - JeepForum.com
post #1 of 3 Old 09-02-2003, 01:53 PM Thread Starter
Fisher
-Hey-
I have a 96 GC. when I turn the heated seats on the light on the display comes on, but I get no heat from the seats. Does anybody know what steps I should take to track the problem down?
Fisher is offline
post #2 of 3 Old 09-02-2003, 06:31 PM
Steven
I can give you my experiences with my Lincoln Town Car.
The upper and lower seats are connected through small vein-like wire patches (in my Lincoln). To make matters worse, the heater pads are individually connected via tiny vein-like wires.
Over time, bending, bouncing, etc these wires crack in places that are nearly impossible to trace down. But it can be done !! Once the break is found it can be cut out and replaced with a better section of flexible wire.
FoMoCo takes that to the next level of misery by gluing the whole electrical system to the leather, covering that with injection foam, and... well you can imagine the rest. But it can be done !!
Diagnosis (in my Lincoln).
1) Check the fuses in accordance with the manual (breakers ??)
2) There is most likely a small solenoid under the seat(s) that "clicks" very faintly as the power is applied to the heaters. If this solenoid sound is heard and there's no heat, the problem is in the seat. If the solenoid never "clicks" the problem is between the lighted switch and the solenoid.
(in my Lincoln)
Sorry, I don't have heated seats in my wife's GC !!
2002 Grand Cherokee, Laredo ( Wife's Ride)
Steven is offline
post #3 of 3 Old 09-04-2003, 01:35 AM
Colorado 5.9
Colorado 5.9's Avatar
There is a TSB/fix for this. This TSB is the most comon thing that goes wrong with the seat heater. However, it sometimes is the main relay on the underside/side of the seat.
Do you hear the relay kick on when you flip the switch? If so, it's probably not that.
The fix is pretty easy if your inclined to doing miner sodering. In the TSB they list the procedure on how to check the heaters in the seat cushon. http://home.sc.rr.com/janet/TSB/08-03-99.htm
The kits are about $15 a piece at the dealer.
ZJ 98 5.9 LTD. Lots of mods. 7" T&T's Long Arm Lift ,BFG KM2"s,35X12.50x16's,4:56's, Vanco brake upgrade, M1intake,Holley52mmTB,MikeLeach Headers,, Arb'ed HP D30,Aussie Locked rear,Procomp MX6 Shocks,Arb front,RearTR bumpers,ECT.ECT.
Colorado 5.9 is offline
Installing heated seats into non heated wj Deah7 ZJ Grand Cherokee Forum 23 10-12-2012 02:08 PM
Installing 98 ZJ heated seats in a 93 with no power seats aaron7 ZJ Grand Cherokee Forum 4 12-28-2008 11:47 AM
Heated Seats Problem GrandHokie96 ZJ Grand Cherokee Forum 8 12-27-2008 02:17 PM
heated seats ZJPunk98 ZJ Grand Cherokee Forum 9 11-22-2005 07:29 PM
Heated Seats Gone Redsand ZJ Grand Cherokee Forum 21 09-30-2005 07:54 PM
