Quantcast load noise after rear diff lock installation- aussie locker - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > load noise after rear diff lock installation- aussie locker
Old 10-09-2008, 11:07 AM   #1
genislav ronen
Hi guys,
I have a situation with my wj and I would like to know if you have any experience with it and how do you think I can solve it –
Here's all the relevant info –
I have a 1999 wj with f+r long arms, 6" lift , front hd tom woods drive shaft ,front chromoly u joint hd axle (dana 30 )+arb air lock , original 247 t case .
Yesterday have installed a rear auto diff lock –Aussie locker.
Since then When I make strong turns in low speed I have a load clunky noise {not the normal click click which I can live with…}– seems like it comes from the jeep's center .
My question is what & why makes this sound ?
is it a bad installation issue ?
is it possible it’s the t case since i am 4x4 all time ?
If I'll swap my 247 t case to 242np will it help ?
What other parts will I need to change if I want to make this swap ? will the 242 fit my rear d shaft {original }?
will it fit my rear end of the front drive shaft ?
Thanks
Ronen
1999 WJ /IRO 6" C.Path LA F&R /clayton's 4 linked rear end /D30-ARB /D44A- Aussie'd /Chromoly U-Joint F.Axle /242hd /4.10's /FOX 2.0 shocks /JKS shock adapters /F.Adj T.Bar /HD double SS/Pitman drop kit /T.Woods F.double cardan d.shaft +pinion yoke&TC yoke /265/75/16 bf mt /Solid HD dana 30 cover/Double open air fillter/ black rock 4" bs /Lower F+R C.Spring Retainers /4" front B. Stops /SUPERCHIP /Addco Rear HD Sway Bar /Rock Sliders /T.case skid plate /HAYDEN hd gear radiator
genislav ronen is offline   Reply With Quote
Old 10-09-2008, 11:12 AM   #2
QuadraTokn
1930 WJ
Not sure exactly what sound your hearing or if its bad or good..
But consider this - I swapped to a 242HD and the my rear aussie locker is almost completely NOT noticeable hen I am in 4 full time.
I currently have my front drive shaft removed because of vibrations. So I drove it in the rain yesterday in 2WD and man i felt unsafe. Even on dry pavement it will lock up around turns a little (in 2WD).
So switching to a 242 and driving in full time will greatly increase road manners.
I have a modified 1999 WJ and a stock 2001 WJ
Tread Lightly
Pictures
PARTED OUT 8 WJ Grand Cherokees ! ! ! ! ! !
QuadraTokn is offline   Reply With Quote
Old 10-09-2008, 11:13 AM   #3
QuadraTokn
1930 WJ
I notice you have MX6 shocks, arent those too short for a 4" lift, esp with LA's?
Tread Lightly
Pictures
Old 10-09-2008, 11:16 AM   #4
champelite210
Mine does it to every now and then. So far I've only noticed while in the grass. Tonight I'm going to a large parking lot to do some circles and see what happens
1998 TJ, 4.0 HO, 5 speed, 3.5" RE Super Flex Adj SA lift, AA SYE, Currie steering, 4.88 Gears, 8.8 Rear with Eaton E-Locker, HP Dana 30 with Detroit locker and chromoly shafts, 36x12.5x15 TSL-SX, TNT Customs front 3.5 fenders, XRC rear crusher corners with 3.5 flare, A to Z rock sliders, PSC steering pump.
champelite210 is offline   Reply With Quote
Old 10-09-2008, 11:59 AM   #5
tozar
If the noise is a banging/klunking type of noise instead of a ratcheting noise then this is somewhat normal. This is from the locker binding up then releasing with a bang. As things wear in, this happens less. The banging type of noise happened a few times when I first installed the locker but after a few thousand miles on it, I haven't heard it in long time.
The locker will always make the ratcheting noise in turns.
I've grown use to the various noises but my wife is always telling me to sell that lemon "It sounds like it is falling apart".
-- Roy
tozar is offline   Reply With Quote
Old 10-09-2008, 01:05 PM   #6
genislav ronen
thanks for the replies guys ,
just to clarify - i am not talking about the ratcheting noise {which i can live with }, i am talking about load clunk noise in hard turns in low speed and it goes loader when accelerating during these turns .
is it damaging the t case?
where can i find 242hd t case ?
ronen
Old 10-09-2008, 01:09 PM   #7
QuadraTokn
1930 WJ
242HD is found in '02-'03 grand cherokees. The difference between swapping the HD over the regular 242 is that you need the rear drive shaft from the jeep the 242HD came from (or a shaft from carolina driveline or tom woods if you have $ to waste) because the aluminum tail housing is longer.
Tread Lightly
Pictures
Old 10-09-2008, 01:49 PM   #8
genislav ronen
what is exactly the difference between 242 and 242hd ?
i have the tom woods d shaft in the front and the rear d shaft is original ,
i will be happy change it to tom woods rear d shaft if the difference between the 242 and the 242hd worth it .
ronen
Old 10-09-2008, 02:03 PM   #9
nierace
2003 WJ
Its normal, mine did that too. Give it a few hundred miles to break in as long as your measurements were within spec. It also alot more noticeable with the 247 that transfercase does not like having the locker out back.
By putting in a 242HD or a 242 and using full time 4wd you will not notice the aussie locker at all really it makes veryy quiet clicking around turns with it even tight ones never binds up.
Nickerdoodle
03 WJ 4.7 242HD Kolak/IRO 5" Clayton LA's
35" BFGoodrich KM2
sira4x4.net North East Offroad Club
www.carolinadriveline.com
www.ironrockoffroad.com
kolak@aol.com
nierace is offline   Reply With Quote
Old 10-10-2008, 02:15 AM   #10
genislav ronen
where can i find np242hd for sale ?
whats the difference between 242 & 242hd ?
thanks
ronen
Old 10-10-2008, 03:08 AM   #11
sandman
did you replace your side gear washers when you installed it? if you didnt, did you use a feeler to check your specs? did you pass the spin test?
1993 Jeep ZJ. 4.0
sandman is offline   Reply With Quote
Old 10-10-2008, 03:19 AM   #12
raider650
Maybe broken or worn Spider Gears.
raider650 is offline   Reply With Quote
Old 10-10-2008, 03:22 AM   #13
sandman
you sir are very confused
1993 Jeep ZJ. 4.0
Old 10-10-2008, 03:28 AM   #14
raider650
Explain yourself.
Old 10-10-2008, 04:08 AM   #15
the88thpianoman
Luck favors the prepared
the88thpianoman's Avatar
2003 WJ
Explain yourself.
The aussie locker replaces the spider gears in the carrier
the88thpianoman is offline   Reply With Quote
Glock Forum
