Little help please - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Little help please
Amsteel Blue Synthetic Winch line Free ShippingRing & Pinion's, Lockers, 4340 Axles, Install Kits, BaRaceline/Allied Wheels on Sale NOW !
Unread 02-26-2012, 08:38 PM   #16
95tuckgrand
Not trying to beat a dead horse here but this is my update:
Have now found a battery drain. It will drop the battery voltage to about 9 volts overnight. Batter checks good. Disconnected the battery overnight and the charge held. I connected a meter in the battery line and removed all the fuses and checked the switch off draw. Fuses 5, 6, and 8 are the only ones that are pulling any power. 5 is the interior lights and stops drawing with the door switch pushed in. 6 is the security module and 8 is the overhead console,VIC, and HEVAC. My guess is the security module but time will tell.
I have changed the spark plugs, distributor cap, and rotor button. Also the fuel filter. I still have the issue of missing at higher RPMs until the engine runs for a while. It doesn't seem to be tied to the temp as it comes up to temp and still misses. It eventually runs smooth as silk through the full RPM range but it takes about 30 minutes of running. Any ideas?
thanks
95tuckgrand is offline   Reply With Quote
Unread 02-26-2012, 09:03 PM   #17
samsonitesamson
I had a similar problem and it turned out the mercury switch in my underhood light was bad and the light was staying on all the time.
When thou walkest through the fire, thou shalt not be burned; neither shall the flame kindle upon thee ~ Isaiah 43:2 ~
Originally Posted by Bnabb View Post
it bolted right up, except one bolt but i didn't need it anyway
samsonitesamson is offline   Reply With Quote
Unread 02-26-2012, 10:11 PM   #18
hdrocknroll
Some Info, check your PMs
Always !! Keep A Firm Grip On Your Tool !!
Watch Out For The Air Hose Gone Wild!! Or Wear A Cup,: True Story
[QUOTE=rooster51;13297693] Whats the worse that can happen? Your jeeps already broke.
[/QUOTE]
hdrocknroll is offline   Reply With Quote
Unread 02-27-2012, 12:28 AM   #19
ratmonkey
Living dead mod
ratmonkey's Avatar
I'd change the coil out for that misfire.
ratmonkey is offline   Reply With Quote
Unread 02-27-2012, 08:17 PM   #20
95tuckgrand
Thanks a lot. That is very good info.
Unread 02-27-2012, 09:02 PM   #21
my-jeep-earl
1971 CJ5
Originally Posted by SAR-Swimmer View Post
Normal to flash after battery diconnected/dead.
Reset procedure,
Turn on ignition, ensure time date function is displayed,
Press/hold SET button until Hour function flashes, then release,
Single tap SET button to set hour, will go up 1 hr per tap,
Press SELECT button, to move to next time/date function, ie min,day,month, adjust settings using single tap of SET button,
Once all settings correct, press SELECT to lock all settings into memory.
ON my '97 GC, i set the DAY, DATE & AM or PM on VIC and the time is set on the radio itself, drove me nutz at first trying to set it.
my-jeep-earl is offline   Reply With Quote
Unread 02-27-2012, 09:09 PM   #22
edpmedic
You tried just holding the set button, not both together like mentioned above.
Never4get those who gave their lives on 09-11-01 WTC and Pentagon. FDNY-EMS-NYPD-PAPD. Also those who are still dying.
_______________________________________________
"Freedom is never voluntarily given by the oppressor; it must be demanded by the oppressed."
Martin Luther King, Jr.
"Always aim at complete harmony of thought and word and deed. Always aim at purifying your thoughts and everything will be well."
Mahatma Gandhi
Feel the Sunshine on your face
edpmedic is offline   Reply With Quote
Unread 03-01-2012, 03:39 PM   #23
my-jeep-earl
1971 CJ5
Just figured out my VIC doesn't have FEB 29th, dumb Jeep, LOL
Unread 03-01-2012, 08:38 PM   #24
95tuckgrand
I did change the coil but still the same issue. I have found an exhaust leak where the exhaust pipe flange connects to the manifold. I don't have any codes active but is it possible that the leak is screwing up the signal from the O2 sensor? Also, the Cat is rattling. I have ordered a new one and will change it anyway. The leak is not as bad after I drive it for 30 minutes or so and the engine also runs with no miss then. Related? Wishful thinking?
Unread 03-03-2012, 08:21 PM   #25
95tuckgrand
Well, got the VIC working. Turns out the select button was stuck in the pressed position. Replaced the entire switch with an old reset button from a PC. Took some creative modifications but it is working great. Now, just need to get it running good. I did a compression test today too, 125-135 psi on all cylinders. FSM says it should be 120-150 so I guess I'm ok.
Unread 07-10-2012, 06:28 AM   #26
95tuckgrand
Finally found the source of my miss thanks to another thread with similar symptoms. The crank sensor was bad. Runs like a top now. Thanks to all who helped.
Unread 07-10-2012, 06:39 AM   #27
KoreaZJ
1994 ZJ
OEM sensor?
KoreaZJ is offline   Reply With Quote
Unread 07-11-2012, 07:38 PM   #28
95tuckgrand
It was an after market sensor. Was that a mistake?
