Quantcast List of Commonly Used Acronyms - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > List of Commonly Used Acronyms
Spartan Lockers FREE SHIPPING Excellent PricesFree Shipping on TIRES at KrawlOff-RoadBlack Magic Brakes - 5% Off, No Minimum Purchase Required
Old 09-22-2004, 12:54 PM   #1
Meerkat
This list of commonly used acronyms is linked to the FAQ.
Please add what you can. I would like to make it as complete as possible.
2WD - two wheel drive
4FT - four wheel drive full time
4LO - four wheel drive low
4PT - four wheel drive part time
4WD - four wheel drive
AAL - add a leaf
ACC - accessory
ACM - airbag control module
ABS - antilock braking system
AECM - airbag electronic control module
ARB - Anthony Ronald Brown
ASDM - airbag system diagnostic module
ATF - automatic transmission fluid
AVG ECO - average fuel economy
BB - budget boost
BCM - body control module
CAB - controller antilock brake
CAL - calibration
CCD - Chrysler collision detection (vehicle communications bus)
CMTC - compass/mini-trip computer (module)
CPS - crankshaft position sensor
CV - constant velocity [joint]
DAB - driver airbag
DC - Daimler Chrysler
DDM - driver door module
DLC - data link connector (same as EDC)
DRB - Digital Readout Box
DRL - daylight running lights
DS - death shake (same as DW)
DTE - distance to empty
DW - death wobble (same as DS)
ECO - intantaneous fuel economy
ECU - engine control unit (same as ECM)
ECM - engine control module (same as ECU)
EDC - engine diagnostic connector (same as DLC)
EFI - electronic fuel injection
EGR - exhaust gas recirculation
ET - elapsed time
FIPK - fuel injection performance kit
HVAC - heater, ventilation, air condition
IAC - idle air control [valve]
IFS - independant front suspension
IOD - ignition off-draw
JTEC - Jeep truck engine controller (PCM)
LA - long arm
LCA - lower control arm (same as LSA)
LD - left door
LR - left rear
LSA - lower suspension arm (same as LCA)
LSD - limited slip differential
MAP - manifold absolute pressure
MET - metric
MIC - mechanical instrument cluster
MSTM - memory seat module
MTR - motor
MUX - multiplexed
NP - new process (same as NV)
NV - new venture (same as NP)
ODO - odometer
OME - Old Man Emu
PAB - passenger airbag
PCM - powertrain control module
PDC - power distribution center
PDM - passenger door module
PTC - positive temperature coefficient
RA - Road Armor
RD - right door
RE - Rubicon Express
RKE - remote keyless entry
RR - right rear
SYE - slip yoke eliminator
TB - throttle body
TBS - throttle body spacer
TC - transfer case
TCM - transmission control module
TPS - throttle position sensor
TSB - technical service bulletin
UCA - upper control arm (same as USA)
USA - upper suspension arm (same as UCA)
US/M - U.S. to metric [button]
VC - viscous coupler
VF - vacuum flourescent display
VIC - vehicle information center
VIN - vehicle identification number
VSS - vehicle speed sensor
VTSS - vehicle theft security system
WOT - wide open throttle
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline   Reply With Quote
Old 09-22-2004, 12:59 PM   #2
PlatinumZJ
Senior Moment Member
PlatinumZJ's Avatar
I don't see HTH
Doug
When all is said and done, more is said than done.
Platinum '97 ZJ LTD, I6 (see profile) Paid for!
Links: Kevin (AKA KOR) for ZJ & WJ stuff,
Kolak for performance stuff. I6 performance info at Dino's jeep 4.0 performance site
Other stuff: Kevin's Roof Rack. KOR sliders, Bored 62mm TB, Blaupunkt Bermuda w/ ipod, Brembo Slotted rotors,
OME steering stabilizer, H4 headlight upgrade...
PlatinumZJ is offline   Reply With Quote
Old 09-22-2004, 12:59 PM   #3
Myrtle Beach
POS -- Piece of -=-=-=-=-=-=-=-=t
[COLOR=navy]---99 Jeep Grand Cheerokee Limited 4.7 V8 -2" Lift -265X75 BFG---[/COLOR]
[URL=http://www.we-todd-did-racing.com/wetoddimage.wtdr/wNTcxOTAxNnM0MTNkZmQzMXk1NDE%3D.jpg]MY JEEP[/URL]
Myrtle Beach is offline   Reply With Quote
Old 09-23-2004, 03:51 PM   #4
JeepStangGuy
FUBAR and RTFM, But seriously I have seen LA used as Long Arm
'97 Jeep ZJ TSi w 5.2L, BB, Iceland Off Road Flares, NP242, 33 MTRs
JeepStangGuy is offline   Reply With Quote
Old 02-10-2006, 10:46 PM   #5
canadia_driver
whats SOA?
canadia_driver is offline   Reply With Quote
Old 02-10-2006, 10:49 PM   #6
Woody
Retired back to Bowties
Woody's Avatar
1985
Spring over axle. It's mostly for the YJ guys who's leafs normally mount below the axle. By relocating the mounts to the top side, a YJ can achieve a near 5" lift with few other parts.
Woody
1985 1 ton K-5, Detroit diesel, 36" tires (going bigger when money permits), 4-speed manual swap, Rockwell T-case, Hybrid lift, 12.5K winch.
Woody is offline   Reply With Quote
Old 02-10-2006, 11:14 PM   #7
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
AW.
Charlie is not seeing if he can do the Spring over axle. Don't confuse him like that.
Hunter
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
http://www.kevinsoffroad.com/
602.841.3355
For your performance needs:
kolak@kolakperformance.com
480.998.3661
Texas ZJ1 is offline   Reply With Quote
Old 02-10-2006, 11:18 PM   #8
-Joe-
always thought of the camshaft position sensor as CPS (Also have seen CMP). isnt the crankshaft something like CKS?
- Joe -
'95 Jeep Grand Cherokee Laredo I6 4.0L
242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs
Moog Cargo Control Springs
Magnaflow Converter - Dynomax Muffler
235/75/15 AT Uniroyal Liberator Tires
-Joe- is offline   Reply With Quote
Old 02-10-2006, 11:32 PM   #9
Airborne Lee
WTF = What the **** As in What the **** is that? or What the **** are you doing!
Sorry for that.
UC = Up country
QD = quadra Drive
KC Jeep Club
M416 Trailer Project
SOLD-01 WJ Limited, 4.7L, QD, UC, Sienna, 2.5" BB, AT/KO 32",
FOR SALE - 01 WJ Limited, 4.7L, QT II, Yakima Rack, CB, GPS, Yellow Top, KC lights, Patriot blue, Skid Plates, New Dahmer 4.7>2000 miles
SEND E-MAIL OR PM
Airborne Lee is offline   Reply With Quote
Old 02-10-2006, 11:41 PM   #10
PullMeSideways
2010 JK Wrangler
You forgot to list my favorite tool "BFH" Big F ing Hammer
2010 2dr Rubicon - Mango Tango!
Colorado Jeep Club Member #11
Former Jeeps:
2002 TJ Sahara, 2007 JK Unlimited Sahara, 2004 WJ & 1986 CJ-7
PullMeSideways is offline   Reply With Quote
Old 02-11-2006, 12:18 AM   #11
Airborne Lee
KOR = Kevins Offroad
SWB = Short wheel base (CJ, YJ, TJ)
LWB = Long wheel base (XJ, ZJ, WJ, WK, KJ, FSJ)
KC Jeep Club
SEND E-MAIL OR PM
Old 02-11-2006, 12:49 AM   #12
seel2000
One that is used a lot:
OEM = Original Equipment Manufacturer
-Seel-
2000 WJ Laredo -- Kevin's 2.5", Rubicon twin-tube shocks, 265/75/16 Firestone Destination MT's, Pioneer head-unit, 800w RockFosg, 2x10 Kicker Comp Subs, Memphis spkrs front&back
2005 WK Laredo
seel2000 is offline   Reply With Quote
Old 02-11-2006, 01:04 AM   #13
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Not to be confused with OME (Old Man Emu)
ArloGuthroJeep is offline   Reply With Quote
Old 02-11-2006, 02:21 AM   #14
Woody
Woody's Avatar
1985
Airborne, XJ's and KJ's are still considered SWB's.
XJ's require an SYE when lifting just as much as a YJ or TJ do.
KJ's don't run SYE's much because most don't lift higher than 1-2" thanks to IFS.
Geez!
Woody
Old 02-15-2006, 08:30 PM   #15
Virmagicus
Headed Out West
Virmagicus's Avatar
PCV = Positive Crankcase Ventilation
Virmagicus is offline   Reply With Quote
Glock Forum
