Is this limited slip test 100% accurate?
| Ruffstuff Axle Simple Swap Kit! | RUBICON EXPRESS Lift Kits and Accessories Available at Bas | Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line |
#1 | |
I have been reading online that you can test for the limited slip by jacking up the back of the Jeep and spinning a tire. If the opposite tire to the tire you are spinning spins in the same direction as the tire you are spinning, then you have a limited slip. If the opposite tire spins in the opposite direction then you don't. Is this test 100% accurate? I requested a build sheet from Jeep and still haven't gotten it yet. I did check the metal tag on the rear axle for "LS" next to the gear ratio as suggested in the forum and didn't see it. I will assume based on this as spinning the wheels there will be enough information to proceed with adding the Supertech synthetic blend 75W-90 gear lubricant I purchased.
#2 |
Mr. Hyde!
If it spins the same direction, then you have LS (assuming it isn't a locker in the back).
However, just because it spins opposite doesn't mean you don't have LS. Some LS systems require spinning before the LS activates so they'll appear open until they spin enough.
'04 WJ, 6" Clayton LA's, 242 SYE, 35" BFG MT KM2's, 4.56 gears, & D44a locked |
#3 |
Got Beer?
Just jack up one side of the Jeep, if you can spin the one tire freely then you probably have open diff's. If you do have a limited slip and can spin just one tire the limited slip is probably worn out.
Previous Jeeps: 84 CJ7 (A True Jeep), 2000 XJ (163,000 Miles/Totaled (Pictures of wrecked Jeep in gallery)) If you don't have time to do it right the first time, how do you have time to do it over. Lifetime member #13 www.militaryjeepers.com lifetime member/airforce26yrs 2011 Tango/Mango JKU |
#4 |
Jeep Jedi Master
Jack it up and do it like Arlo said.
Hunter
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns and 33 Bridgestone Duelers Detroit and true trac Red Jeep Club Member REDNECK JCM Texas Jeep Owner #6 USN Jeep Club #4 http://www.kevinsoffroad.com/ 602.841.3355 For your performance needs: kolak@kolakperformance.com 480.998.3661 |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
