limited slip diff additive??? - JeepForum.com
post #1 of 9 Old 03-07-2009, 04:46 PM Thread Starter
painted600rr
just need to know how much limited slip diff additive to put in my wj. front diff
painted600rr is offline
post #2 of 9 Old 03-07-2009, 05:19 PM Thread Starter
painted600rr
i guess no ones ever changed their fluids
post #3 of 9 Old 03-07-2009, 06:49 PM
rm2001wj
rm2001wj's Avatar
For the front, it's 2.5 - 3 oz if you have QD, otherwise it's zero.
rm2001wj is offline
post #4 of 9 Old 03-08-2009, 05:18 AM
sandman
i guess your a smart *** and have no patients. seriously you didnt even wait a half an hour for a response, calm down.
1993 Jeep ZJ. 4.0
sandman is offline
post #5 of 9 Old 03-08-2009, 04:41 PM
cloiselle
what if you've used a diff oil such as " severe gear " by amsoil that has some FM already in it, use a little less and test it out to begin with ?
i'm having some lock up front and rear in tight turns with the S G oil alone, was considering adding 1/2 an oz to both front and rear , driving it and checking it out .. adding more ( 1/2 oz at a time ) until the limited slip stopped binding on tight radius turns.... sound like a reasonable method ?
cloiselle is offline
post #6 of 9 Old 03-08-2009, 06:59 PM
EMTimZJ
GSMW!
EMTimZJ's Avatar
1994 ZJ
How are you testing/experiencing this "lock up?"
-Tim
KD8EBC
'94 ZJ 5.2 LTD
JCR Rock Sliders
EMTimZJ is offline
post #7 of 9 Old 03-08-2009, 08:01 PM
the88thpianoman
2003 WJ
Only your front diff? If you have quadradrive, you have front and rear ls diffs. Your owner's manual tells you how much mopar stuff to add, or you can just order up some Amsoil severe gear, which already has it included in the mix.
2003 WJ in Jeep Green Metallic, 4.0/242/4.10's. 4" Teraflex springs w/ RE monotube shocks and IRO short arms, cheap intake w/ amsoil filter, 2.5" hi flow cat and back exhaust, lots of lights and other misc crap.
Check out my build thread here:
the88thpianoman is offline
post #8 of 9 Old 03-09-2009, 12:18 AM
cloiselle
both of them are locking up, pulling into a parking space and and slowing down at a sharp turn angle causes one front tired to skid momentarily dpending on left or right turn... and it's not from hard braking .. rear end in tight circles makes a whirring / moaning noise that never happened before with the stock mopar oil and FM. also the outer tire leaves a nice little rubber trail , it's not being allow to spin quicker than the inside wheel...
has to be this lack of fm in the severe gear i've switched too .. i didnt break anything while it was on the lift getting changed to amsoil ! thats for sure
post #9 of 9 Old 03-09-2009, 12:19 AM
cloiselle
i have severe gear, still getting some noises and binding in TIGHT circles with it.
doesnt do much on normal turns and regular driving, do a figure eight and you WILL hear it ! : (
Limited Slip Additive NewAlbanyWJ ZJ Grand Cherokee Forum 20 11-12-2013 05:23 PM
WK Diff fluid change. Limited slip additive? mllr WK Grand Cherokee & XK Commander Forum 4 04-27-2009 08:33 PM
Limited slip additive? ///BHRpowered ZJ Grand Cherokee Forum 8 11-16-2006 10:17 AM
Limited Slip Additive blakely03 ZJ Grand Cherokee Forum 1 04-04-2006 11:10 PM
Limited Slip Additive ALS59LTD ZJ Grand Cherokee Forum 4 10-21-2002 06:59 AM
