Limited Slip Additive - Page 2 - JeepForum.com
post #16 of 21 Old 02-18-2009, 12:53 PM
jondilly1974
Thanks for the info!
jondilly1974 is offline
post #17 of 21 Old 02-18-2009, 01:23 PM
BLACKzj52
Originally Posted by Wheelin98TJ View Post
Too much friction modifier will make the limited slip work less effectively.
i see. well good thing when we went to install my lsd we couldnt get the carrier out (needed a spreader), cuz i had mobile 1 and FM i was going to put it
My Build Thead
Facebook
BLACKzj52 is offline
post #18 of 21 Old 10-16-2009, 05:53 PM
plac
good to know. I think I will return my standard basic Valvoline and then get the Mobil 1.. just so i dont have to hunt down any additives. wish i had seen this thread before i bought..
if you had to choose between 75-140 and 75-90 which would you choose. it doesnt get cold here in Cali..
2015 Subaru WRX
plac is offline
post #19 of 21 Old 11-12-2013, 10:27 AM
Jerry1964
Hello,
The chart on this thread says to use 2.5 ounces of friction modifier to front and rear axle.
This chart says to use 2.5 front and 4 ounces rear.. http://www.wjjeeps.com/service/maintenance_wj.htm#TCASE
So, what is the real story?
Also, which rear differential do I have on my WJ 2000 with Quadra-Drive, 4.7 V-8? I believe it to be the Dana 44 but would like verification please.
And...What is the proper Mopar PN for the limited slip additive?
Thanks,
Jerry1964
Jerry1964 is offline
post #20 of 21 Old 11-12-2013, 12:01 PM
Jerry1964
Hello,
Another question regarding the Limited Slip Additive (LSD).
The link I provided http://www.wjjeeps.com/service/maintenance_wj.htm#TCASE says to "add" the LSD to the differential fluid.
Do you put the LSD into the differential fill hole and then top off with the 75w140?
Thanks,
Jerry1964
post #21 of 21 Old 11-12-2013, 04:23 PM
rlcii77
Ha, I was reading this thread and didn't notice that it's info. pertaining to a WJ, not a ZJ, until more than halfway through it.... lol So, you WJ guys have LSD in the front of your Jeeps as well, huh???
'94 Limited ZJ (CRUSHED, kept the 5.2L, 46RH & 249 TC)
'96 Orvis ZJ
'98 Slate 5.9 ZJ (DD)
rlcii77 is offline
WK Diff fluid change. Limited slip additive? mllr WK Grand Cherokee & XK Commander Forum 4 04-27-2009 07:33 PM
limited slip diff additive??? painted600rr ZJ Grand Cherokee Forum 8 03-08-2009 11:19 PM
Limited slip additive? ///BHRpowered ZJ Grand Cherokee Forum 8 11-16-2006 09:17 AM
Limited Slip Additive blakely03 ZJ Grand Cherokee Forum 1 04-04-2006 10:10 PM
Limited Slip Additive ALS59LTD ZJ Grand Cherokee Forum 4 10-21-2002 05:59 AM
