Limited Slip Additive - JeepForum.com
post #1 of 21 Old 02-03-2009, 06:13 AM Thread Starter
NewAlbanyWJ
2007 XK Commander
I am going to be changing out my differential fluids this weekend...I have to change the front because I will be replacing the axle seals, the rear will just be maintenance. Do I have to buy the limited slip additive from the dealership, or does Autozone or Advance carry something similar?
I know some of you will say to just buy Royal Purple or Amsoil gear oil, but I've already bought, opened, and used some of the Mobil 1 because I had to add a little bit of fluid to the front diff due to the leaking seal. So I'd rather not spend any extra money on gear oil.
Thanks in advance...
Mine: '06 Dodge Ram 1500 4x4 Big Horn Ed., 5.7L Hemi
Hers: '07 Commander Limited 4x4, 4.7L
(Former WJ owner, hence the screen name)
NewAlbanyWJ is offline
post #2 of 21 Old 02-03-2009, 06:16 AM Thread Starter
NewAlbanyWJ
2007 XK Commander
Edit:
I see that Amsoil makes an additive. Would this be a good substitution for the Mopar? I work with an Amsoil dealer, so if I can use this instead I'll just do that.
post #3 of 21 Old 02-03-2009, 07:20 AM
Ridin' Around
Yes that will do the job & it's cheaper!
Ridin' Around is offline
post #4 of 21 Old 02-03-2009, 07:29 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
If you're using Mobil 1, you will not need limited slip additive.
Its already in there.
Wheelin98TJ is offline
post #5 of 21 Old 02-03-2009, 07:33 AM Thread Starter
NewAlbanyWJ
2007 XK Commander
Really?? Well that's good to know. At $18 something per quart, it should already be in there.
post #6 of 21 Old 02-03-2009, 07:40 AM
newfieZJ
I thought things were cheaper in the US , that`s the same price as here . I went with Royal Purple , I know it`s got a good rep , and , I got it for $15 a quart , no FM additive required .
I`d go with Amsoil if I was south of my boarder just because of the good representation from Ridin' Around , but shipping kills the deal here in Canada
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #7 of 21 Old 02-03-2009, 07:46 AM
Wheelin98TJ
JEEP FREAK
Mobil 1 has an excellent reputation too. Its good stuff.
And it definitely has the limited slip additive already.
post #8 of 21 Old 02-03-2009, 10:50 AM
xJoshxx
2012 WK
yep even tho i like amsoil thnx to ridin around i used M1 before i knew about amsoil yes $18 per qt atleast u dont need gallons of it i could image O_O
Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 ORA2 sold
2012 WK2 SRT8 - Current
99 WJ Limited Lifted.
2001 WJ stock 4.0 304k miles
xJoshxx is offline
post #9 of 21 Old 02-03-2009, 10:53 AM
BLACKzj52
wow that interesting
so what happens if u use mobile 1 and put in the fm?
BLACKzj52 is offline
post #10 of 21 Old 02-03-2009, 10:55 AM
WA_WJ
2003 WJ
I always thought mobil1 didnt have any FM, cause the dealerships always sold that with the fm.
2003 Overland 31" KM 2's
WA_WJ is offline
post #11 of 21 Old 02-03-2009, 11:14 AM
xJoshxx
2012 WK
i guess ull have SUPER FM NO FRICTON AT All!
I think m1 only the Higher grade stuff has the FM alrdy it has to say on the bottle for it have it
i just used 70w140 it didnt sayanything about it but i also have dana 30/35 with out trac locks
2011 WK2 ORA2 sold
xJoshxx is offline
post #12 of 21 Old 02-03-2009, 01:16 PM
Wheelin98TJ
JEEP FREAK
Too much friction modifier will make the limited slip work less effectively.
Dealerships rarely use mobil 1. They just fill from the drums and use additives.
ALL Mobil 1 has the friction modifier already.
Mobil 1 is the higher grade stuff. There are not 2 different levels of Mobil 1 oil.
They do not make a 70-140, but there is a 75-140 Mobil 1.
http://www.mobil.com/USA-English/Lub..._LS_75W-90.asp
http://www.mobiloil.com/USA-English/...75W-140LS.aspx
post #13 of 21 Old 02-03-2009, 01:52 PM
xJoshxx
2012 WK
so i miss type Oh i see now the bottle says 75w140
2011 WK2 ORA2 sold
xJoshxx is offline
post #14 of 21 Old 02-18-2009, 11:55 AM
jondilly1974
Dumb question here, but what are the capacities for the front and rear differentials on the 2000 WJ 4.0l 4x4? Need to now how much to buy.
jondilly1974 is offline
post #15 of 21 Old 02-18-2009, 12:08 PM
Wheelin98TJ
JEEP FREAK
Below are the fluid capacities.
1 quart = 2 pints
WK Diff fluid change. Limited slip additive? mllr WK Grand Cherokee & XK Commander Forum 4 04-27-2009 07:33 PM
limited slip diff additive??? painted600rr ZJ Grand Cherokee Forum 8 03-08-2009 11:19 PM
Limited slip additive? ///BHRpowered ZJ Grand Cherokee Forum 8 11-16-2006 09:17 AM
Limited Slip Additive blakely03 ZJ Grand Cherokee Forum 1 04-04-2006 10:10 PM
Limited Slip Additive ALS59LTD ZJ Grand Cherokee Forum 4 10-21-2002 05:59 AM
