Limited Slip Additive - JeepForum.com
post #1 of 2 Old 04-04-2006, 09:17 PM Thread Starter
blakely03
1997 GC 5.2L NP249 Towing Package w/ Limited Slip
I was at Napa picking up supplies to change diff. fluid. I read on the back of both bottles of limited slip additive "not for use in Jeeps with quadra trac"...Is this stuff OK to use in the diffs? Or should I just go get the additive from the dealer?
Also, do I need to put additive in both the front and rear diffs?
blakely03 is offline
post #2 of 2 Old 04-04-2006, 11:10 PM
SET2JET
i am 99% sure that they mean not to use it in the t-case... what lube did you get? if your front diff is limited slip then yes put it in but i don't believe it is although if you add it to a non-limited slip it won't hurt anything
SET2JET is offline
Limited Slip Additive NewAlbanyWJ ZJ Grand Cherokee Forum 20 11-12-2013 05:23 PM
WK Diff fluid change. Limited slip additive? mllr WK Grand Cherokee & XK Commander Forum 4 04-27-2009 08:33 PM
limited slip diff additive??? painted600rr ZJ Grand Cherokee Forum 8 03-09-2009 12:19 AM
Limited slip additive? ///BHRpowered ZJ Grand Cherokee Forum 8 11-16-2006 10:17 AM
Limited Slip Additive ALS59LTD ZJ Grand Cherokee Forum 4 10-21-2002 06:59 AM
