Likely failing CV axle - JeepForum.com
post #1 of 8 Old 08-25-2013, 02:28 PM Thread Starter
RoldGold
So while turning right sharply at high speeds (35+), I can hear a rhythmic rubbing sound. I know CV axles click when they need to be replaced, but this is less of a click and more a rubbing noise. If necessary I could probably capture the sound with a camera.
My question is, does this still sound like a possible explanation? And is there a specific brand of CV axle I should look for? I read somewhere of someone using Moog axles but I'm unable to find any on rockauto.
Thanks!
1996 Grand Cherokee Limited 4.0L
PSC Steering Gear; NP249 w/ new VC; Moog TRE's, Track Bar, Stabilizer bar bushings and endlinks, control arm bushings
Still no lift, and almost no paint on the hood
RoldGold is offline
post #2 of 8 Old 08-25-2013, 02:49 PM
PolkaPower
Is the boot ripped?
PolkaPower is online now
post #3 of 8 Old 08-25-2013, 05:55 PM
jabba974
Hmm..I would also look at the hub bearing....
jabba974 is offline
post #4 of 8 Old 08-26-2013, 02:30 PM Thread Starter
RoldGold
Originally Posted by PolkaPower View Post
Is the boot ripped?
No, but there is pretty much no grease in there. I can move the boot and expose the internals easily.
RoldGold is offline
post #5 of 8 Old 08-26-2013, 02:31 PM Thread Starter
RoldGold
How would one go about checking that?
RoldGold is offline
post #6 of 8 Old 08-27-2013, 07:17 PM
BigDaveZJ
I would lean towards the hub too. One method is to jack that wheel off the ground, grab it at 6 and 12 and give it a good shake, similar to testing for ball joints. Unit bearings are pretty easy to place, although based on your location I would invest in some PB Blaster to get it all apart. In addition to the tools needed to get the wheel and brake caliper off, you will also need a 36mm socket, and a 12pt 13mm socket and/or wrench. If you don't have air tools, my recommendation would be to take the wheel off, and before you take the caliper off, loosen the 36mm hub nut. Easiest to do that with the brake on, and having a helper use the brakes to hold everything in place while you go at the 36mm hub nut with a breaker bar, which you will need if you don't have air tools. A hi-lift handle is a good substitute if you don't have a breaker bar.
95 ZJ with lots of stuff
14 WK2
BigDaveZJ is offline
post #7 of 8 Old 08-28-2013, 08:05 PM
jabba974
A little FYI..if you don't have a helper to hold the brakes, take a heavy screwdriver, and insert it into the rotor and brace it against the caliper braket...this makes geting the hub nut on and off...
jabba974 is offline
post #8 of 8 Old 08-29-2013, 08:49 PM Thread Starter
RoldGold
Ok everyone, I've got all the info I need. Thanks, and I'll look into it when I get some more funding...
RoldGold is offline
