Quantcast lights problem - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > lights problem
DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-TJ 5.25" Speaker Adapters - NalinMFGFree Shipping on TIRES at KrawlOff-Road
Old 09-14-2006, 10:40 AM   #1
laxwarriors21
lights problem
Whats up guys, havent posted much in awhile... but the Jeep is acting up again
Ok so.. I think it was 2 days ago or something, I go out of my jeep, turned out my lights and noticed that my drving lights didnt turn off... front or back, and neither did my cluster gauge lights... couldnt figure how to turn em off, so I was like whatever and went inside... came out the next day, and just as i expected the battery was dead, got my friend to try and jump it but all it did was click rapidly, no cranking or anything when i tried to start it, so 2 questions...
When he tries to jump start me again, should we let it charge my battery for a little bit like 10-15 mins then try to crank it
And anyone know why my parking lights wont go out?
thanks in advance
[URL=http://www.cardomain.com/member_pages/view_page.pl?page_id=678654]'96 [COLOR=White]White[/COLOR] Grand Cherokee Limited V8 5.2L[/URL]
--4.5'' RE Lift
--31'' x 10.50'' Firestone Desination MT's
--Trail ready bumpers
--Conferr roof rack
--Two Hella Model 500 driving lights
laxwarriors21 is offline   Reply With Quote
Old 09-14-2006, 10:45 AM   #2
sand zj
Yes you need to charge your battery for a while before trying this will also help keep your alternator from frying. When totally dead you alt will work long and hard to recharge thus causing it to heat up wich is the biggest enemy of electrical components...heat. You may just have a bad switch, that is where I would start, seems the most probible to me.
Dan
[B]If you don't get stuck, keep trying![/B]
'96 ZJ 7" LA, 318, 231, 8.8 (welded), d30 (LockRight), 4.10's, 33x13.5x16 TSL's, no interior...
sand zj is offline   Reply With Quote
Old 09-14-2006, 07:32 PM   #3
laxwarriors21
I let it charge for about 15 mins on my friends battery, and still nothing but that same old rapid click when I try to start it... could a starter be the culprit?
--4.5'' RE Lift
--Conferr roof rack
Old 09-18-2006, 12:14 PM   #4
laxwarriors21
bump... need help please!!
--4.5'' RE Lift
--Conferr roof rack
Old 09-18-2006, 12:17 PM   #5
nierace
2003 WJ
Usually rapid click means not getting enough power bad connection, make sure you have the jumper cables on there good, clean the contact points and what not then try again. You may just wanna pick up a new battery to try as well.
I'm not sure about the parking lights...
Nickerdoodle
03 WJ 4.7 242HD Kolak/IRO 5" Clayton LA's
35" BFGoodrich KM2
sira4x4.net North East Offroad Club
www.carolinadriveline.com
www.ironrockoffroad.com
kolak@aol.com
nierace is offline   Reply With Quote
Old 09-18-2006, 12:22 PM   #6
PugetHound
Parking lights is most likely the switch, try cleaning it with electric contact cleaner and it sounds like bad battery cables/conections/corrosion, etc.
PugetHound is offline   Reply With Quote
Glock Forum
