Lights on front bumper... airflow problem? - JeepForum.com
post #1 of 35 Old 12-14-2009, 06:37 PM Thread Starter
the88thpianoman
2003 WJ
I have a couple 6" low profile lights, basically a pair of knockoff Hella 500 FF's. They'll fit perfectly mounted to the lip of the bumper right in front of the grill, but should I be worried about how much airflow these are potentially going to block? I just put in a brand new mopar cooling fan, but don't want to push my luck too much. Has anyone running a similar setup run into any cooling problems or has it been just fine? I'll take experience and speculation here
2003 WJ in Jeep Green Metallic, 4.0/242/4.10's. 4" Teraflex springs w/ RE monotube shocks and IRO short arms, cheap intake w/ amsoil filter, 2.5" hi flow cat and back exhaust, lots of lights and other misc crap.
Check out my build thread here:
the88thpianoman is offline
post #2 of 35 Old 12-14-2009, 07:32 PM
biggoofy
i cant see if being a problem or any worse than having a winch so i think ull be ok
and where in tampa u at
Zack
98 Slate Grey 5.9
96 ZJ HP44 / 9" (RIP)
90 XJ on 33s (sold)
biggoofy is offline
post #3 of 35 Old 12-14-2009, 07:59 PM
GrandLaredoWJ
I have two 6" lights similar to what you have on my front bumper and have had no air flow problems that i notice. I think that the electric fan pulls enough air through the radiator regardless of how many lights are on the bumper.
'00 Grand Cherokee/Rally Jeep-Ojibwe Forests Rally Heavy Sweep #95 -4" Teraflex Lift, Homemade Adj. Longarms, 33x10.50 BFG All Terrains, 4.2L built, bored, blueprinted & balanced, Lots more..
Red Jeep Club Member #499
MN Jeeper #48
Black '75 CJ5- Built 304, 4.88's, Dana 44 Spooled, Dana 30 Spooled, 4" lift, 35x12.50 tires
GrandLaredoWJ is offline
post #4 of 35 Old 12-14-2009, 08:00 PM
MurdaJs
I have 2 6" hellas on my bumper, no problems that i notice, and i notice a lot of **** lol
MurdaJs is offline
post #5 of 35 Old 12-14-2009, 08:22 PM Thread Starter
the88thpianoman
2003 WJ
Thanks for the replies, all, I'll be putting these lights on soon. Also, I'm just a few minutes north of USF in tampa.
post #6 of 35 Old 12-14-2009, 08:37 PM
jeepgc99lmtd
1955 CJ3A
I have a couple light mounted on my brush guard right in front of my grille and I havent had any problems.
1999 WJ, 4" BDS Suspension Lift, Cragar 342 Series Wheels, Westin Front Brush Guard, 265/75/r16 Cooper STT's FOR SALE!!
1955 Willy's M38A1 Project
jeepgc99lmtd is offline
post #7 of 35 Old 12-14-2009, 09:23 PM
FrankTheDank
got the iceland bumper and haven't cut lower vents in it and have the winch on front, no overheating
::4.0::42RE::242::Carolina Driveline::Spartan Locked D30::Aussie locked 44A::4.56!!!::4'' IRO LA::33/12'' Retreads::4"BS wheels::IRO T case skid::2 12'' Kenwood Subs 1000 Watt Kenwood Amp::Iceland Winch Bumper::Smittybilt XRC8::
STOCK 97 ZJ LAREDO-Daily Driver
I don't need to lie...that way I never have to remember what I said
FrankTheDank is offline
post #8 of 35 Old 12-14-2009, 09:54 PM
CrazyIvan888
The early ZJs came with the option of having auxiliary lights factory-mounted in front of the grille.
CrazyIvan888 is offline
post #9 of 35 Old 12-14-2009, 10:06 PM
rooster51
Im going to disagree W/ everyone thus far, based on geography. The southernmost state these replies came from is North Carolina, a world of difference from Tampa. It gets HOT in Florida. When I went surfing at Treasure Island and got stuck at the bridge I could see my temp. rise. That was in a mustang w/ no blockage to the radiator.
I would find another way to mount them to the bumper without blocking the rad.
Terry
rooster51 is offline
post #10 of 35 Old 12-14-2009, 10:08 PM
97DCZJ
I had the 700FF's which are 7" and I had no problem with airflow.
The problem I did have was they wobbled horribly. Make some brackets if you plan on putting them there, not bolted directly to the bumper cover
1997 Grand Cherokee Orvis: V8 5.2L, stock.
(Sold) 1998 Cherokee Sport: 4.0L I6, Stock.
(Sold) 1990 Cherokee: 4.0L I6, 4.5" Lift, 33" BFG's.
(Sold) 1997 Grand Cherokee Limited: V8 5.2L, 2" BB, 31" Dick Cepeks.
(Sold) 1999 Grand Cherokee Laredo:
; V8 4.7L, Stock.
(Sold) 1996 Grand Cherokee Laredo:
; V8 5.2L ,3.5" lift, 32" Tires
97DCZJ is offline
post #11 of 35 Old 12-14-2009, 10:13 PM
Bama_WJ
Bama_WJ's Avatar
I have 3 Hella 500s right in the center of my grille on my bumper and have had zero problems during the hottest of days in July/August (around 100*F). Never overheated.
Daniel
Current Stable: 2001 WJ, 2006 WK, 2006 TJ
Bama_WJ is offline
post #12 of 35 Old 12-14-2009, 10:20 PM
rooster51
Was that in Indy or Bama? It STAYS 100plus in Tampa during summer, all summer.
Maybe I just had a bad year there.
Terry
post #13 of 35 Old 12-14-2009, 10:24 PM
97DCZJ
sitting on a bridge with a motor idling in 100+* weather n the temp going up has othing to do with the lights being in front of the rad. unless you have a piece of wood or plate blocking the grill COMPLETELY, it isn't going to effect it.
; V8 4.7L, Stock.
97DCZJ is offline
post #14 of 35 Old 12-14-2009, 10:33 PM
rooster51
__________
Terry
post #15 of 35 Old 12-14-2009, 10:45 PM
Bama_WJ
Bama_WJ's Avatar
That's in Alabama. It doesn't get 100 until about July, but its still pretty hot the rest of the summer. All in all, I don't think 2 lights are going to cause you any problems.
Daniel
Bama_WJ is offline
Aftermarket lights for front bumper on a WJ 98XJLimited ZJ Grand Cherokee Forum 13 12-12-2006 06:35 PM
why to not mount fog lights IN your front bumper 01ACRViper ZJ Grand Cherokee Forum 5 11-05-2006 09:34 AM
airflow problem BOBBYBARLOW ZJ Grand Cherokee Forum 1 08-04-2006 09:07 AM
Heater/Aircon Airflow Problem BOBBYBARLOW ZJ Grand Cherokee Forum 0 07-05-2006 04:33 PM
bumper/front mounted lights? hrjaw ZJ Grand Cherokee Forum 11 12-05-2004 10:26 PM
