Lifting Zj help - Page 4 - JeepForum.com
post #46 of 51 Old 03-23-2014, 08:53 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Well, stay within your budget and go to 3.5. 33s are going to suck your gas like crazy.
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #47 of 51 Old 03-23-2014, 09:42 AM Thread Starter
sharpie54
I'm not to worried about gas. I have 3.73 gearing so a little better than normal gear ratio
sharpie54 is offline
post #48 of 51 Old 03-23-2014, 09:56 AM
PolkaPower
3:73 is normal for all v8's. 4.0 came with 3:55 unless the customer wanted 3:73's like with a tow package. We know what gears came with what. What did you think was normal gear ratio for the 5.2?
3:73's will be a dog with 33's. I know for a fact because I had that for a while.
When you lift it the axles get closer to the body and decrease the wheel base. 33's will rub the body without adjustable control arms to push the axles back near the stock position. You also need to have front and rear adj track bars to center the axles because they will get pushed out to the drivers side in the front and to the passenger side in the rear so they will be crooked.That causes problems in the front with sway bar end links and puts stress on the steering components. In the rear the endlinks will also be crooked and can hit the spring. It also wears out the control arms faster because they are effing crooked.
PolkaPower is online now
post #49 of 51 Old 03-23-2014, 09:59 AM Thread Starter
sharpie54
Well it's not going to be a race jeep. But I also don't want to be a rolling tank(not in the good way)
post #50 of 51 Old 03-23-2014, 10:06 AM
PolkaPower
Just go ahead with your plan. I want to see the results. I think we have different opinions about ride quality and essential lift parts.
post #51 of 51 Old 05-09-2014, 10:00 AM Thread Starter
sharpie54
Just found out my front lower control arms are adjustable. Never noticed till now. What will they help with?
adjustable control arms , lift advice , track bar
