Lifting Zj help - JeepForum.com
post #1 of 51 Old 03-20-2014, 11:39 AM Thread Starter
sharpie54
Lifting Zj help
Hi im new to this forum. I have a 1995 jeep grand Cherokee Orvis edition. Just bought it a few months back for $500. Has 160,000 miles and a 5.2 v8. Already has a 3 inch coil lift. I'm putting another 3 inch bb lift on soon. I plan on getting front upper adjustable arms and a front adjustable track bar as soon as I put the lift on. Its going to be my dd and a little off-roading on the weekends. Nothing serious. What else MUST I need? I'm doing the cv front driveshaft swap to U-Joint. Just wondering what else im missing?
sharpie54 is offline
post #2 of 51 Old 03-20-2014, 12:43 PM
PolkaPower
A 3" BB on top of 3" springs is going to ride like a burnt turd. Ditch the spacers. If you want 6" of lift to ride nice for a DD on short arms you better break out the Jacksons and don't stop until there are around 12 of them.
PolkaPower is offline
post #3 of 51 Old 03-20-2014, 12:50 PM
WhiteOut
WhiteOut's Avatar
Expect to spend about $1200-$1500 to do this.
All 8 adjustable control arms, all new shocks, adjustable front and rear trackbars, bumpstop extensions, probably front brake lines, misc steering components.
WhiteOut is offline
post #4 of 51 Old 03-20-2014, 08:44 PM
Vertical4
2014 JK Wrangler
Feel free to browse around our webtsite and see if there is anything that interests you in completing you build! Let me know if you have any further questions or comments on any parts.
-Jim at Vertical4
GO WHERE OTHERS FEAR
Vertical4 is offline
post #5 of 51 Old 03-21-2014, 10:16 AM Thread Starter
sharpie54
I just need to know what I need. I'm only 18 and I drive to school and back so I really don't care about ride quality. Which arms MUST I need to drive? I know front upper for pinion angle, and I know front adjustable track bar for centering the axle. My shocks are for 4-8 inch lift, I have brake line extensions already. Thanks
post #6 of 51 Old 03-21-2014, 11:06 AM
WhiteOut
WhiteOut's Avatar
- Front and rear upper/lower adjustable control arms
- Rear adjustable trackbar.
- Longer swaybar links
- Proper lift springs for your desired height
- Since you can't run without it, you will need to swap the driveshaft to a ujoint style. You either need to swap the yoke at the diff or get the adapter plate
WhiteOut is offline
post #7 of 51 Old 03-21-2014, 01:12 PM
nnovickzj
why do you want to lift it another 3 inches?
97 zj 5.2 40,000mi
locked front and rear, 242, 3.5 iro lift, 32x11.5 kenda klever, 28 laredos for the road
4x 130 watt 6" spots on the roof rack, h3 leds in stock fogs, 2 40w leds on the grill
nnovickzj is offline
post #8 of 51 Old 03-21-2014, 02:22 PM
RangeDrive
Ok I'm from a small country town where the higher the truck the more of a man you are so I see where your coming from but still why not run 3.5 with 33s and call it a day. 6 plus inches of lift is alittle extreme don't you think?
RangeDrive is offline
post #9 of 51 Old 03-21-2014, 02:26 PM
WhiteOut
WhiteOut's Avatar
For a DD, he might not want to do extensive body modification.
WhiteOut is offline
post #10 of 51 Old 03-21-2014, 02:31 PM
RangeDrive
point taken, didn't think about that
post #11 of 51 Old 03-21-2014, 02:42 PM Thread Starter
sharpie54
I've know many jeep guys who got away with 5-6 inches of lift without all 8 adjustable control arms. And because 6 inches looks the best. I don't like the look of 3 inches at all. Don't want to cut the body at all either. It's gonna be a mall crawler more than anything. I'm used to a horrible ride quality any ways so I really don't care about that
post #12 of 51 Old 03-21-2014, 02:53 PM
WhiteOut
WhiteOut's Avatar
ZJs are much different than other Jeep models, the things listed are needed.
If you want a Jeep to run 33s cheaply, pick up a TJ or YJ. ZJ and XJ models are going to be much more to lift.
Even if you decide to go without most of the proper parts, the driveshaft replacement is not optional. Removing the front shaft is not an option on your Jeep.
WhiteOut is offline
post #13 of 51 Old 03-21-2014, 03:15 PM Thread Starter
sharpie54
Yes I know. I stated in my very first thread comment that I was changing my cv shaft to ujoint first off. But thanks. I'm obviously on a budget and plan on having all the adjustable arms, but first off I will only be able to afford front uppers, which are the most important
post #14 of 51 Old 03-21-2014, 03:41 PM
PolkaPower
Do you know what happens to the axles when you lift a ZJ that high without having all adjustable control arms?
post #15 of 51 Old 03-21-2014, 06:34 PM
nnovickzj
wait till you have all the adjustable arms then put the pucks in 8 adjustable arms is really the minimum for 6 inches of lift on a zj you should really have long arms but we understand that your not going to pay for them so we gave you the cheapest option the bare minimum both track bars adjustable arms spring post extensions the drive shaft and sway bar links you asked for what you needed and the people here who together know everything about your jeep answered with your budget in mind.
97 zj 5.2 40,000mi
adjustable control arms , lift advice , track bar
