Lifting the head out of the engine bay? - JeepForum.com
post #1 of 6 Old 05-06-2013, 01:11 AM Thread Starter
AVR2
So I've got everything stripped off the head and it's time to get the bolts out. I'm starting to wonder how much of a PITA it's going to be to actually lift the head off the block? Anything I should know in advance?
I'm working in the parking lot of my apartment building, so there's no way of using chains or similar to lift it.
AVR2 is offline
post #2 of 6 Old 05-06-2013, 09:35 AM
blown50
1987 YJ Wrangler
Getting it off is no problem, just get it off the dowels,slide it around sideways and lift it out ! Now going back on can be a problem cause you don't want to slide the head on the new gasket! But it can be carefully placed back on, I set mine on top of the dowels, so it's not touching the gasket, get it close by using the dowels to slide on, then just drop the back into place then the front! The head is heavy so be sure to eat your wheaties before you start
blown50 is offline
post #3 of 6 Old 05-06-2013, 10:08 AM Thread Starter
AVR2
Sorry, what do you mean by "the dials"?
AVR2 is offline
post #4 of 6 Old 05-06-2013, 10:54 AM
Oldfrog
2007 WK
He meant "dowels".
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
post #5 of 6 Old 05-06-2013, 11:40 AM
blown50
1987 YJ Wrangler
Originally Posted by Oldfrog
He meant "dowels".
Yea
blown50 is offline
post #6 of 6 Old 05-06-2013, 11:41 AM Thread Starter
AVR2
Just did it about 30 minutes ago... you're right, it just lifted out to the side, but OMG it was heavy to lift from that angle...
AVR2 is offline
