Lifting 98 ZJ 5.9L - Page 2 - JeepForum.com
post #16 of 46 Old 08-05-2013, 07:59 PM
kg6mov
Hears the voices
kg6mov's Avatar
IRO all the way, especially for a niner you want to keep the 249.
kg6mov is offline
post #17 of 46 Old 08-05-2013, 08:02 PM
Kevinyj95
That's what I thought. I thought it was the stronger TC.
Kevinyj95 is offline
post #18 of 46 Old 08-05-2013, 08:05 PM
kg6mov
Hears the voices
kg6mov's Avatar
You might also think about rehearing if you're going to dd it. It will kill what little gas mileage you had left and feel like a 4.slow.
Sent from my iPad Nano using JeepForum
kg6mov is offline
post #19 of 46 Old 08-05-2013, 08:09 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
He meant re-gearing..... re-hearing is what ... wait, did I hear that noise from the back porch again?
Hunter
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #20 of 46 Old 08-05-2013, 09:15 PM
tucsonzj
Hunter
*yelling* MMMAAALLLLLLL-CCCCRRRRAAAAWWWWLLLEEERRRR! sorry couldn't resist
Originally Posted by Kevinyj95 View Post
Im at 4" with 31s and I wouldn't want to go with bigger tires.
seriously? I'm at 3" and my 31's have plenty of room. Once I throw the new springs in and get the money i much rather run 33's. And if he's planning on seriously wheeling it, 33's or 35's are going to be much better. Depending on his willingness to spend all the money to lift, new ca's, replace ds, regear, and start replacing front end parts as they fall off hehe. Not to mention a possible axle swap down the road.
His:00 TJ "Fiona" stuff/stuff/stuff
95 ZJ 3.5" w/242 swap-Sold
Hers: 15 JK Sahara-3" Teraflex
tucsonzj is offline
post #21 of 46 Old 08-05-2013, 09:54 PM Thread Starter
zbaldry
I just threw up thinking about how much all that would run.
Would I need to re gear at 4.5"?
zbaldry is offline
post #22 of 46 Old 08-05-2013, 10:58 PM
GCjunkie93
Gearing has nothing to do with lift height. With larger tires and stock gear ratio it will feel more sluggish and kill what pathetic mileage you get. If your going to run 33's/35's, I would re-gear to a 4.56 ratio.
1993 ZJ 5.2 V8-Some Stuff/Beater
1984 CJ7 258/Auto/Dana 300/Daily Driver
GCjunkie93 is offline
post #23 of 46 Old 08-06-2013, 12:37 AM
Kevinyj95
dont forget to buy spacers.
post #24 of 46 Old 08-06-2013, 03:09 AM
tucsonzj
if you're planning on keeping stock rims. If you're buying aftermarket rims just make sure you get ones with backspacing of 4 or less
tucsonzj is offline
post #25 of 46 Old 08-06-2013, 04:52 AM
PolkaPower
PolkaPower is offline
post #26 of 46 Old 08-06-2013, 05:27 AM
hondakilla98
I've got 4" of lift on my 5.9 with 32" tires. It's not bad driving it around town. I usually turn OD off unless I'm on the freeway. Otherwise it keeps kicking into OD and your driving 45 mph at 1300rpm. Which is annoying.
5.9 Limited, RE 4" lift, RE FTB, JK take offs w/ 255/75/17 BFG MT's, 1.25" wheel adapters, ARB Bumper, Superwinch LP10000, K&N intake, Flowmaster, custom JL & Focal stereo, 20% tint, KOR roof mount tire carrier, JCR sliders, cobra 75 wx st
hondakilla98 is offline
post #27 of 46 Old 08-06-2013, 10:32 AM Thread Starter
zbaldry
Thanks for the advice everyone!
zbaldry is offline
post #28 of 46 Old 08-06-2013, 10:45 AM
sandman92k
I run the RC long arm on my 5.9, no problems other than just plan on buying a complete set of shocks from some where else, the shocks suck and wont last ( unless they have fixed them) and plan on the passenger side sitting lower than the front. (used ACOS to adjust it out)
sandman92k is offline
post #29 of 46 Old 08-08-2013, 01:54 PM Thread Starter
zbaldry
Any reviews on this kit? Will I need control arms? My drive shafts are u-joint style.
http://www.ironrockoffroad.com/Merch...egory_Code=PFZ
zbaldry is offline
post #30 of 46 Old 08-08-2013, 02:17 PM
kg6mov
Hears the voices
kg6mov's Avatar
For 4.5" you really should think about adjustables to keep pinion angles in check.
IRO is good stuff. It all depends on what kind of ride quality you're willing to live with. For $1k I don't know that 4.5" is a reasonable goal.
If you stay with stock CA's you should check the condition of the bushings and replace as necessary (I prefer to replace the whole arm, its not much more $ and way easier).
kg6mov is offline
1998 , 5.9l grand cherokee zj , lift , zj
