Lifting 98 ZJ 5.9L - JeepForum.com
post #1 of 46 Old 08-05-2013, 01:15 PM Thread Starter
zbaldry
Lifting 98 ZJ 5.9L
Starting to look into lifting my 5.9L. How high can I lift before I have to start replacing drive shafts, brake lines, etc? I will be doing the work myself, is there anything different than the 5.2L that I need to look out for. Any suggestions on lift kits under 1k. Thanks for the advice.
zbaldry is offline
post #2 of 46 Old 08-05-2013, 04:30 PM
fljeepney
How high are you planning to lift it?
1993 ZJ 4.0 Laredo
1998 ZJ 5.9 Limited
1985 Corolla AE86 coupe
fljeepney is offline
post #3 of 46 Old 08-05-2013, 06:49 PM Thread Starter
zbaldry
Looking at 4-4.5" rough country
zbaldry is offline
post #4 of 46 Old 08-05-2013, 06:58 PM
Kevinyj95
You will be fine just make sure the lift comes with control arms. Depending how long your brake lines are you may have to unbolt the bracket. Im at 4" which was suppose to be5.5. But anyways no problems with shafts or brake lines. Needed new sway bar links and track bars because the kit did not come with them. Other things to make sure the kit comes with.
Kevinyj95 is offline
post #5 of 46 Old 08-05-2013, 07:10 PM Thread Starter
zbaldry
zbaldry is offline
post #6 of 46 Old 08-05-2013, 07:15 PM
fljeepney
For around 400 more than your second choice,this is a great kit.
http://www.ironrockoffroad.com/Merch...egory_Code=PFZ
1993 ZJ 4.0 Laredo
1998 ZJ 5.9 Limited
post #7 of 46 Old 08-05-2013, 07:16 PM
tucsonzj
if you ask my opinion, dont do rough country, many around here will agree. Some will say it's ok, not good though. Use the search button, these questions have been answered about 1000 times.
To answer your question, usually about 3.5" you need new brake lines. Every zj is a little different so it just depends.
The real question is what size tire do you want to run? Wheeling this jeep or just for driving around town? I still recommend going Iron Rock Off Road or Rubicon Express. Either way if you search around you'll see all these lifts have been covered in depth on what you need besides the lift or need to junk from that lift and replace with something better. Basically you can do a 3.5" lift without replacing control arms and brake lines. Doesnt' mean it's not an advantage to do so or you caster will be off and you'll get drive line vibes if you don't.
Depending on your wheeling status, assuming you have a cv style front drive shaft and you're planning on going to a bigger tire size (i'll say 33" or above) you need that to be replaced with a u-joint type.
His:00 TJ "Fiona" stuff/stuff/stuff
95 ZJ 3.5" w/242 swap-Sold
Hers: 15 JK Sahara-3" Teraflex
tucsonzj is offline
post #8 of 46 Old 08-05-2013, 07:22 PM Thread Starter
zbaldry
That is worth looking at for sure. What is the purpose of lowering the transfer case with that kit? I currently have the 249 is it worth the swap and cost to go with a 242?
zbaldry is offline
post #9 of 46 Old 08-05-2013, 07:37 PM
tucsonzj
answer my questions and i'll tell you.
if its a dedicated trail rig, do the 242 or 231 swap. Never use a t-case drop with a zj, it's not needed.
tucsonzj is offline
post #10 of 46 Old 08-05-2013, 07:39 PM
Kevinyj95
I have been hearing nice things about Ironrock offroad. Im considering a spring swap from rancho to iron rock.
post #11 of 46 Old 08-05-2013, 07:40 PM
Kevinyj95
Just curious why a tc swap?
post #12 of 46 Old 08-05-2013, 07:41 PM Thread Starter
zbaldry
It wont be a pavement princess, I take it off road frequently. It is my daily driver however.
zbaldry is offline
post #13 of 46 Old 08-05-2013, 07:44 PM Thread Starter
zbaldry
I want to run 32" or 33". I plan on getting a kit that includes new control arms.
zbaldry is offline
post #14 of 46 Old 08-05-2013, 07:54 PM
fljeepney
If you go with Iro's 4.5 kit,you will get all new control arms,plus in the future,they have a long arm option for the front and back.
You also have the option of getting adjustable CA's with this kit too.
1993 ZJ 4.0 Laredo
1998 ZJ 5.9 Limited
post #15 of 46 Old 08-05-2013, 07:57 PM
Kevinyj95
Im at 4" with 31s and I wouldn't want to go with bigger tires. Go with a 5.5 I wish I did. Remember replacing the cv ds involves changing the connection the u joint style wont bolt up to the cv style. I want to do this after I get a new vc. Mostly because I misplaced mine and the new cv ds is 700$.
1998 , 5.9l grand cherokee zj , lift , zj
