Lifting a 96ZJ? - JeepForum.com
post #1 of 27 Old 04-20-2011, 02:04 AM Thread Starter
tanner1025
Lifting a 96ZJ?
has anyone put this lift on? anyone know of issues on this kit, i am sorta on a budget only planning on running 31's or 32's will trim. so i was looking at this kit then getting a good steering stabilizer to go with. what else do i need please let me hear some opinions.
tanner1025 is offline
post #2 of 27 Old 04-20-2011, 02:20 AM
TheHalfWit
This might sound like a really stupid question, but which lift?
TheHalfWit is offline
post #3 of 27 Old 04-20-2011, 03:58 AM Thread Starter
tanner1025
post #4 of 27 Old 04-20-2011, 03:58 AM Thread Starter
tanner1025
link didnt come up the first time sorry
post #5 of 27 Old 04-20-2011, 05:46 AM
mrfister11
use your stock wheels and you dont need to trim.. just watch out when you really tuck you might get in the pinch weld and when you turn all the way you might rub on control arms.. depends on the tire your get. as far as putting that lift on.. that lift is exactly like any other lift with spacers. so pretty much everyone on here has messed with the pucks. not any harder than replacing springs.. just spend extra money and get adj trackbars. other than that you dont need anything. just fix your toe-in when you do this
mrfister11 is offline
post #6 of 27 Old 04-20-2011, 05:53 AM
Dyn0mitemat
If its staying on the road it'll be fine, but you're going to get alot of people saying not to run over 2-2.25" pucks
Dyn0mitemat is offline
post #7 of 27 Old 04-20-2011, 11:31 AM
Erbo1Kanerbo
you get what you pay for its a cheap kit that will ride like ****
ZJ Build thread:
ZJ's: If you dont know what it is you cant afford it.
Erbo1Kanerbo is offline
post #8 of 27 Old 04-20-2011, 12:01 PM
MStaffin
I looked into this lift.. I actually decide not to use it. I wonuldn't feel safe wheeling with a 3in puck. Also the ride may suck or would be unsafe to use off road. I know someone on here has them he likes it but, idk what kind of wheeling he dose. Id go with the IRO 3.5. Or for a f>r swap with UC and a 2in or 2.225 puck up front before I run a 3in puck.
00 WJ Zone4in Clayton longarms and linked rearD30/D35 4.88s 33s locked
MStaffin is offline
post #9 of 27 Old 04-20-2011, 12:02 PM
rdrbssr11
*edit*
after looking at it more, i'd probably skip using spacers that thick. i think you'd be better off with a traditional 2" spacer kit.
-95' grand cherokee w/ 5.2. ARB & xd9000. IRO 4.5" w/ 33's. 8.8 & HP 30 w/ 4.10's both aussie locked and some other goodies.
-97' grand cherokee w/ 4.0. stock.
rdrbssr11 is offline
post #10 of 27 Old 04-20-2011, 12:06 PM
MStaffin
Actually those pucks measure 3in.
Edit* on a zj 2in pucks give you a bit of room. You can clear 31s nicely with little to no trimming. I wish I could clear 31s on my wj with the 2in bb. Also, zjs sit higher with a 2in bb then a wj.
MStaffin is offline
post #11 of 27 Old 04-20-2011, 08:53 PM Thread Starter
tanner1025
ok say i really just like to trail and find a mud hole, i would like to stay with 31 or 32's. what would you guys consider a nice lift?
post #12 of 27 Old 04-20-2011, 09:16 PM
MStaffin
Ill tell you 2 is not enough. Im looking into 3.5 and more. But idk which brand toget. Im thinking IRO.
Sent from my droid phone using JeepForum
MStaffin is offline
post #13 of 27 Old 04-20-2011, 09:26 PM Thread Starter
tanner1025
i dont what to go that high because then shi* breaks, drive-train, trans, rubbing ect.
post #14 of 27 Old 04-20-2011, 09:29 PM
rdrbssr11
the iron rock offroad 3.5" foundation kit is pretty nice for the money. it runs $329...
http://www.ironrockoffroad.com/Merch...egory_Code=ZLK
post #15 of 27 Old 04-21-2011, 12:53 AM
HeavyArms
The IRO foundation kit is good for the money but ur best off spending the bit extra to get the double sheer trackbar. Its worth the extra money because you'll need it.
its also worth investing in a rear adjustible trackbar. I bought a bracket and regretted it.
Wiggle wiggle wiggle
HeavyArms is offline
axle swap on 96zj bigcarl ZJ Grand Cherokee Forum 12 12-17-2010 06:16 AM
5.9 swap into a 96zj sweetJEEP318 ZJ Grand Cherokee Forum 1 02-05-2010 12:35 AM
96zj 4.0 cuts in and out while driving?! 1sportsdoc ZJ Grand Cherokee Forum 9 04-18-2009 07:05 PM
02 transmisson into 96zj? don birkbeck ZJ Grand Cherokee Forum 1 04-18-2009 04:42 PM
what does a 96zj keyless entry remote look like? jordan_fehlman ZJ Grand Cherokee Forum 15 03-05-2009 10:43 PM
