Liftgate Window Won't Unlock - JeepForum.com
post #1 of 5 Old 10-29-2012, 10:27 AM Thread Starter
philstricker
Liftgate locks and unlocks no problem. Problem is that the window in the liftgate will not unlock. I removed the back panel and found out that I can manually unlock the window by pressing down on the long gold piece (sorry I don't know the proper name for it, circled in picture). I checked the wire connections and nothing is loose.
I'm wondering if someone can help me figure out the next steps. How do I figure out why pressing the release button doesn't trigger this gold piece to move down and unlock the window. Any help would be appreciated.
BTW I tried WD-40 just for kicks, didn't fix anything.
1998 4.0 L6 Laredo ZJ 214,000
philstricker is offline
post #2 of 5 Old 10-29-2012, 10:43 AM Thread Starter
philstricker
I also checked the fuses and they are all fine so that's not the problem.
post #3 of 5 Old 10-29-2012, 01:56 PM
98GCLimited
Watch the lift gate glass solenoid (the thing you pushed on to unlock the glass) when you hit the unlock button if it doesnt move then the solenoid needs to be replaced or your wiring is shorted or broken somewhere. Most likely the solenoid (hopefully).
98GCLimited is offline
post #4 of 5 Old 10-29-2012, 05:54 PM Thread Starter
philstricker
Thanks for the reply.
I disconnected the solenoid wiring and used a multimeter to test the continuity and got a reading. Didn't get a reading on the rest of the wire (the part the solenoid plugs in to. Worried that it's probably faulty wiring.
Any advice on what wiring I should look at maybe buying?
post #5 of 5 Old 10-29-2012, 05:57 PM Thread Starter
philstricker
Just found another thread with same problem.
http://www.jeepforum.com/forum/f13/z...-latch-533027/
liftgate , locked , rear window
