Lift questions for 96 Grand Cherokee - JeepForum.com
post #1 of 5 Old 08-19-2013, 02:37 PM Thread Starter
pstldrvn1
I have a stock '96 Grand Cherokee and I want to put just a 2" lift on it.. I have the AWD model and have read different things that brought up some concerns. some have said you cant put a lift on an AWD, also have read that if you lift it, (even just 2"), that it will mess up the drive shaft and other stuff. I previously owned a '96 Cherokee Sport and put a 1.5" lift on it and never had any issues after that and owned it a few more years after the lift.. just want to be sure its safe before I do the lift and tear up anything... Any help and suggestions are much appreciated! THX!
pstldrvn1 is offline
post #2 of 5 Old 08-19-2013, 02:40 PM Thread Starter
pstldrvn1
and I don't know if it helps, but the lift I am looking at is 4 coil spring spacers, 4 shocks, and bumper stops
post #3 of 5 Old 08-19-2013, 03:15 PM
WhiteOut
WhiteOut's Avatar
For just a 2" budget boost, you'll be 100% fine leaving everything as is. Unless there are worn components under there like your steering, trackbar or controls arms,; then you are more likely to get death wobble once the added height stresses those parts more.
WhiteOut is offline
post #4 of 5 Old 08-19-2013, 03:24 PM Thread Starter
pstldrvn1
Thx WhiteOut.. I have to change the driver side spindle, tie rods and pretty much redoing the front end so shouldn't have an issue there. Just wanted to be sure the lift would fit and not tear up anything. thx again
post #5 of 5 Old 08-19-2013, 09:56 PM
coltman151
Just make sure to rebuild the front end before the lift. Save yourself some headache.
I'm not the same drivetrain as you, but I have a bb and really felt no difference in ride from stock except peeking over a few more cars
95 Laredo 4.0, 2" RE BB, RC N2.0 Shocks, Custom Roof-Mount Light Bar w/ 6 lights, Bumpers deleted, Homemade sway bar discos, Michelin LTX 31x10.50s, and a Dog Box :)
Planned: Homemade Spare tire carrier, double shear front track bar, 4 adjustable rear control arms, New Rims and 33" Wrangler MT/Rs or BFG M/T KO's w/ LOTS of trimming.
coltman151 is offline
