Lift Question about 93 ZJ - JeepForum.com
post #1 of 6 Old 07-04-2013, 12:23 PM Thread Starter
prettyinjeep
hey! i have a 93 zj with a 3.5in rough country suspension lift and it's currently sitting on 32x11.50x15 falken rocky mountain at tires.
my question is, i'm looking to give it a bit more lift, without spending the $1,200 on a larger lift. has anyone ever tried putting coil spring spacers on in addition to the lift?
something like this is what i was looking at...
http://www.ironrockoffroad.com/Merch...egory_Code=ZLK
thanks!
girls can drive, too. ♥ 93 ZJ. 3.5in rough country suspension lift on 32s.
prettyinjeep is offline
post #2 of 6 Old 07-04-2013, 12:24 PM
riot1987
yes you can if you have all the other components to support the taller lift you can add spacers on top of the spring
Build thread^^
riot1987 is offline
post #3 of 6 Old 07-04-2013, 12:27 PM
riot1987
There is a reason why taller lifts are more expensive. Its more than just throwing on tall springs and calling it good. What are you currently running? 3.5" RC is a bit vague
Build thread^^
riot1987 is offline
post #4 of 6 Old 07-04-2013, 12:27 PM
WhiteOut
WhiteOut's Avatar
Make sure you have
- All 8 adjustable control arms
- Shocks for 5.5" of lift
- Swaybar links front and rear
- Adjustable trackbars front and rear for correct height
- Front driveshaft converted to u-joint
Then you can go and put that $60 spacer set on.
WhiteOut is offline
post #5 of 6 Old 07-05-2013, 04:39 PM
tucsonzj
Originally Posted by WhiteOut View Post
Make sure you have
Lol seems worth it right. Spend the money or don't do it. You'll spend more money fixing the crap you break after doing it wrong the first time, then buying the new lift anyways
His:00 TJ "Fiona" stuff/stuff/stuff
95 ZJ 3.5" w/242 swap-Sold
Hers: 15 JK Sahara-3" Teraflex
tucsonzj is offline
post #6 of 6 Old 07-05-2013, 09:29 PM
dnuccio
Make sure you have
this^
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
