Lift question - JeepForum.com
post #1 of 2 Old 05-11-2001, 04:02 AM Thread Starter
airdough49
Lift question
I have a 93 grand cherokee 4x4 and want to put a little larger tires than the normal 31"-10.50 allowed by a 3" lift. I kind of want to put 32-11.50's or maybe 33's. Is this possible without doing major modifications such as a longer drive shaft, etc. I really only want to modify the suspension if possible.
airdough49 is offline
post #2 of 2 Old 05-18-2001, 10:24 PM
The Grand Pooh-Bah
1973 FSJ Wagoneer
This is more complex then you might expect. Which lift are you considering? Not all 3" lifts give you 3" of lift. Some more some less. Then there is the settling. And what other mods you have like ARB bumper, winch, rock rails, trail gear, roof racks ect. Then the tires are not all sized equal. If you get a set of 32" BFG Muds and set them next to a 32" Super Swamper you are going to have one that is significantly taller.
Yes you can put 32" tires on some 3" lifts but you will have to do lots of trimming. (Nothing that a good grinder, sawzall and a hammer won't cure.)
You won't have to deal with driveshafts with a 3" lift.
I would recommend Teraflex, Rubicon Express and Skyjacker. They are all good kits and stand behind their equipment. Teraflex probably has the best street ride and easiest disconnects.
For more info and sources go to www.nagca.com
The Grand Pooh-Bah is offline
lift question. thinking of going bigger and now i am slightly confused about old lift Irish_Assassin ZJ Grand Cherokee Forum 12 01-22-2009 01:17 PM
Lift Question - NO ITS NOT THE SAME OLD QUESTION - i hope Intense-Dakota ZJ Grand Cherokee Forum 15 02-08-2008 03:22 PM
Lift Question mudlover1832 ZJ Grand Cherokee Forum 1 03-24-2007 06:57 PM
Yet Another Lift Question Vectork39 ZJ Grand Cherokee Forum 4 03-15-2005 04:14 AM
WJ lift question walter_da_jpr ZJ Grand Cherokee Forum 1 08-30-2004 09:21 AM
