Lift ? - JeepForum.com
post #1 of 6 Old 11-25-2005, 07:10 PM Thread Starter
BradTE20
Lift ?
I have a 04 WJ that I want to lift, it's gonna be my daily driver for a while. Anyone have any opinions regarding the 4" Teraflex vs. the 6? I'm wondering if 6 is too big, although i've heard 33s rub pretty bad with just the 4.I have to keep in mind though I will use it to commute to work.
BradTE20 is offline
post #2 of 6 Old 11-25-2005, 07:19 PM
FPKites
ZJjazzyJim
FPKites's Avatar
6 will probably be a bit much for a DD. Arlo should be able to give you some more insight, if not sell you his BB when he goes bigger (wink, wink). I've read that 33s would be okay with some minor trimming. I really wouldn't want to go 33 on a DD though. 32 would be my limit.
Jim Karlin
"Duh! Big RED Jeep!!!"
or
96 ZJ Laredo
5" lift, Claytons, KOR radiator support, rear bumper, steering brace, etc, etc, etc.
04 WJ Overland
Clean.... :D
FPKites is offline
post #3 of 6 Old 11-25-2005, 07:19 PM
rrubio
rrubio's Avatar
You can do a search and get tons of info.But the skinny on the subject.The Tera kit sucks.4"and you will have to trim to fit 33's without a doubt. 4" with 33's will hinder your wheeling as well.Best combo is 32's with a 4-4.5 of lift.6" is a big step and alot more money then a 4" lift.If you do go to 6" get Clayton's Long Arms that is the way to go.
rrubio is offline
post #4 of 6 Old 11-25-2005, 07:39 PM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
And get your 4" lift from www.kevinsoffroad.com under WJ lifts. Has a good comprehensive kit put together that uses some of Teraflex's kit and some other stuff in it.
Expect to spend around $2000 + tires/wheels for a 4" lift + 32's.
I wouldn't go 6" w/o long arms as Ramon said...Hunter has a 4" lift + 2"BB to compensate for...He is running like that just fine.
-Ryan
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #5 of 6 Old 11-25-2005, 07:59 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
There is one thread on here from JU about a guy running 6 inch short arm lift for a WJ that he make work.
However, the normal 4 inch lift from Kevins is the way to go. Arlo hit that perfectly.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #6 of 6 Old 11-25-2005, 08:45 PM Thread Starter
BradTE20
thanks guys for quick responses, yea i definitely wouldn't do 6 w/ out long arms, that'd be a nice ride
BradTE20 is offline
ZJ Front to rear lift How much lift should i expect? jeep95xj ZJ Grand Cherokee Forum 32 07-10-2017 05:06 PM
BDS 2" Lift vs. Budget Boost lift csi ZJ Grand Cherokee Forum 14 04-20-2009 02:26 PM
iron rock offroad 4.5 premium lift, or rubicon xpress 4.5 lift? jeepheller98 ZJ Grand Cherokee Forum 22 02-08-2009 09:34 PM
lift question. thinking of going bigger and now i am slightly confused about old lift Irish_Assassin ZJ Grand Cherokee Forum 12 01-22-2009 01:17 PM
Max towing with lift/trail blazer lift s2gots ZJ Grand Cherokee Forum 6 11-03-2006 06:00 AM
