Lifespan of front driveshaft w/IRO 3" WJ lift - JeepForum.com
post #1 of 12 Old 12-20-2007, 12:40 PM Thread Starter
dickensheets
I'm close to ordering the 3" kit.
I don't want to buy a new front driveshaft though.
Will it live thru light to medium wheeling?
Ryan 99WJV8 w/247tc
99 WJ V8, 245/75/16 MT/R and Rusty's 2.5" coils and shocks, IRO trac bar, homespun end links, block heater!! 220V MIG w/75-25 and OXY/Acetalene rig if you need it! Just let me know
dickensheets is offline
post #2 of 12 Old 12-20-2007, 12:55 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
yes, it will live for a long time.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #3 of 12 Old 12-20-2007, 02:36 PM
txtumbleweed
Hunter
Not my experience.
Ryan: Not sure how many miles you got on your 99/4.7/247TC WJ or if you are still on the original front shaft. If you do have the original CV style shaft, take a look at the CV joint rubber seal of the drive shaft at the TC side of the shaft. That rubber seal does not like the angles caused by lifts. Mine failed shortly after installing an OME lift. Swapped to double cardan after it failed and all is well. I think the CV style shaft is reasonably strong and should support the "light to medium" wheeling you described , but do expect that seal to fail at some point down the road with 3ins of lift.
Y2K WJ 4.7
txtumbleweed is offline
post #4 of 12 Old 12-20-2007, 02:54 PM Thread Starter
dickensheets
ok so I guess i'll just have to see for myself.
Tumbleweed, is that boot replaceable, I know it's small/odd shaped. I will worry less if I can throw a $8 boots at it occasionally.
Thanks gents.
Ryan
post #5 of 12 Old 12-20-2007, 04:34 PM
gcjeeping
gcjeeping's Avatar
My stocker lasted almost a year with a 6" lift. Then got a new one made. 390 bucks well spent.
_____________
gcjeeping is offline
post #6 of 12 Old 12-20-2007, 04:37 PM
CLNinja
CLNinja's Avatar
do the ZJs have this same problem? ive been at 4.5" inches and mine is fine
Matt
**September 2009 Grand Cherokee Of The Month**
CLNinja is offline
post #7 of 12 Old 12-20-2007, 06:31 PM
DesertWJ00
Mine was already going bad from my previous 2"bb/up-country spring set-up. It was toast and making load vibration noises after I installed the 3" springs. The older style D.S. doesn't seem to be able to handle over 2" lift. Got the newer-style u-joint shaft and it works great now. It is even greasable now.
2000 WJ 4.7 Laredo
Tow & skids/IRO 3"/JKS Adj. TB/MX-6's/SS/265/75/16 BFG AT/4.11 Yukons/Addco/Stillen brakes & caliper upgrade/New front D.S./Kolak 3" exhaust/FIPK/bored 68.5 TB/HO cams & intake/Superchips
DesertWJ00 is offline
post #8 of 12 Old 12-20-2007, 08:14 PM
txtumbleweed
Thanks gents.
Ryan
Not replaceable to my knowledge. You can always keep an eye on it and drive it until the seal fails and tosses the grease. Then replace. Double cardan will last longer than the CV.
Y2K WJ 4.7
post #9 of 12 Old 12-21-2007, 02:42 AM
Colorado 5.9
Colorado 5.9's Avatar
It's not the boot the fails. It's the joint. This kind of shaft has very little slip along with not handling the angles. Once you disco & start flexing the axle, that's when it fails. Basically it just gets pulled apart.
Mine lasted 3 whole trips wheeling. The last being the hardest trail with the most flexing. When it snapped I wasn't even on anything. It was nice & level.
http://www.imagestation.com/album/pi...?id=4292106177 View it one last time before it's gone.
ZJ 98 5.9 LTD. Lots of mods. 7" T&T's Long Arm Lift ,BFG KM2"s,35X12.50x16's,4:56's, Vanco brake upgrade, M1intake,Holley52mmTB,MikeLeach Headers,, Arb'ed HP D30,Aussie Locked rear,Procomp MX6 Shocks,Arb front,RearTR bumpers,ECT.ECT.
Colorado 5.9 is offline
post #10 of 12 Old 12-21-2007, 08:29 AM
EisBlade
De Oppresso Liber
EisBlade's Avatar
This thread compliments what we have going on here as well.
http://www.jeepforum.com/forum/showt...82#post4571982
I have a '99 WJ with CV on both ends of the front drive shaft as well. Included in that thread above is the approximate price if you converted to a Tom Woods.
EDIT: It's suggested to grease the u-joints/double cardan as often as oil is changed.
Asked over there, but will include it here - is there an alternative to Tom Wood double cardan shafts or is that pretty much the standard to consider moving to?
JT
Harley-Davidson Touring Bikes (60K members strong)
EisBlade is offline
post #11 of 12 Old 12-21-2007, 08:50 AM
txtumbleweed
You can also go with the MOPAR double cardan replacement (I think it is TSB 030500) which also flashes tranny to make it a 545RFE (if your 4.0L, you'll have different tranny). Can't see the TSB data on WJJeeps lately. MOPAR shaft looks pretty beefy. I have had mine on for 40K (?) now with no problems. Quieter too than the CV joint set up.
Y2K WJ 4.7
post #12 of 12 Old 12-21-2007, 12:57 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
He is correct.
However, with only the 3 inch lift and very mild wheeling....his quote, he should be fine.
Now, I've seen Bruce at GSE bust two CV driveshafts in less than 30 minutes. SkyjacktZJ had his CV one replaced with the double carden one made at a local drivetrain shop. They are much better.
It used to be the standard that all ZJs/ WJs with that CV jointed front driveshaft had them replaced with a better / beefier CV jointed one or a double carden.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.366
4.7 lifespan cloiselle ZJ Grand Cherokee Forum 6 07-19-2009 09:13 PM
3" lift = driveshaft and steering issues? mtnjam ZJ Grand Cherokee Forum 5 09-30-2007 08:35 PM
2" front driveshaft ? merkur92 ZJ Grand Cherokee Forum 11 01-14-2007 07:51 PM
~5.5" lift people, driveshaft vibes... rdrbssr11 ZJ Grand Cherokee Forum 3 11-25-2006 03:35 PM
WJ N*249 VC lifespan CF ZJ Grand Cherokee Forum 5 05-01-2005 11:39 PM
