Quantcast Life of the ZJ V8? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Life of the ZJ V8?
JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!JKS products - Free shipping! Lowest prices!East Coast Gear Supply- Quality Diff Parts
Old 08-13-2008, 08:19 PM   #1
MickeyZJ
Life of the ZJ V8?
Hey,
My 96 ZJ with the straight 6 is beginning to become a money pit the engine is at a point where I am thinking of buying a newer ZJ and swapping out the lift and tires. I know a decent amount the 4 liter but what can I expect out the V8? I am looking at a 98 limited with the V8, 113000 miles.
I'm 17 and learning, breaking plenty of parts in the process.
'96 ZJ
3.5" RE Super-Flex
MickeyZJ is offline   Reply With Quote
Old 08-13-2008, 08:22 PM   #2
Ultimatecarman4
I can't speak for every one, but my 5.2 has 156K on it and is running 95% like new.
Ultimatecarman4 is offline   Reply With Quote
Old 08-13-2008, 09:17 PM   #3
Katesdad
Katesdad's Avatar
If its been taken care of it should last along time.
Katesdad is offline   Reply With Quote
Old 08-13-2008, 09:23 PM   #4
moparrr07
the chrysler 4.0 will run for 300k miles
the small block chrysler will run for 300k miles+ IF the oil is changed every 3k miles
-Black Limited 1998 Jeep ZJ 5.2 44re 242 swap UC package- 2 inch BB, OME steering Dampner, custom cai, e-fan swap, kolak cat back
moparrr07 is offline   Reply With Quote
Old 08-13-2008, 10:18 PM   #5
Shelbyzz
I got 186,000 on my 97 5.2L idles like a pretty little kitty - Then step on the throttle and ROOOAARRRR!!! -with a glass pack of course - but still runs perfect, not an engine problem yet!!
Shelbyzz is offline   Reply With Quote
Old 08-13-2008, 10:22 PM   #6
tirus89
got 166xxx on mine and still runs good. No rattles, no knocking, no pinging, no codes except for the 02 sensor.
Im a student and unemployed and have a Haynes.
//93 ZJ//5.2L//NP249//K&N Fipk Gen II//2" BB w/BD AT Shocks//4.10's//31" Cooper Discovery STT's//Cstm Frnt Bmpr//Custom Rear Tube Bmpr//3" Magnaflow exhaust w/high flow cat//500RMS Pioneer Amp//600RMS 12" JL Audio Sub//4 Hella 500's on Cstm Light Bar//Sealed Intake Box w/ ram air//
tirus89 is offline   Reply With Quote
Old 08-14-2008, 12:15 AM   #7
CMARJEEP
If its been taken care of then it should last for a very long time. But every engine is different. You could have a major malfunction at 150k or it can perform flawlessly for 300K miles. It all depends how it was previously cared for and how you care for it. I suggest if you do buy it then change all of the fluids and do a tune up on it so you know that it was all done and when.
-Connor KI6TMX
www.norcaljeepers.co
CMARJEEP is offline   Reply With Quote
Old 08-14-2008, 01:24 AM   #8
jeepheller98
at 146K but some quality oil and lucas it and no zero problems as far as the motor *knock on wood*
98 ZJ 3" lift homemade snorkel. JKS quicker disco 5.2L 150,000, 31x10.5 pro comp muds
jeepheller98 is offline   Reply With Quote
Old 08-14-2008, 04:35 AM   #9
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
I've put over 200K on two different 5.2 motors. One in a 83 Ramcharger and then the Grand.
Hunter
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
http://www.kevinsoffroad.com/
602.841.3355
For your performance needs:
kolak@kolakperformance.com
480.998.3661
Texas ZJ1 is offline   Reply With Quote
Old 08-14-2008, 10:40 AM   #10
moparrr07
i saw a dodge diplomat with a 318 with 730k miles no typo, never had the heads off, ran super smooth
Old 08-14-2008, 10:49 AM   #11
ajmorell
ajmorell's Avatar
I get a kick out of you "Every 3 months or 3000 miles" guys - you obviously don't know jack about oil.
Andy
'98 Jeep ZJ "Pearl"
ajmorell is offline   Reply With Quote
Old 08-14-2008, 11:26 AM   #12
LaCeS OuT
1994 ZJ
I had a reman installed at 152k after my 5.2 blew a head gasket. That was lack of maintenance though. Plus I beat the **** out of it with towing and such.
Jeep Sold! 02/2009
Need AMSOIL? Click Here!
LaCeS OuT is offline   Reply With Quote
Old 08-14-2008, 12:55 PM   #13
the88thpianoman
Luck favors the prepared
the88thpianoman's Avatar
2003 WJ
Just tuned up the girlfriend's 5.2 ZJ... purring like a kitten with 203,XXX miles
2003 WJ in Jeep Green Metallic, 4.0/242/4.10's. 4" Teraflex springs w/ RE monotube shocks and IRO short arms, cheap intake w/ amsoil filter, 2.5" hi flow cat and back exhaust, lots of lights and other misc crap.
Check out my build thread here: Life lessons and budget build
the88thpianoman is offline   Reply With Quote
Old 08-14-2008, 01:25 PM   #14
aaron7
heh yah, the 3 months / 3000 miles thing is a scam.
Anyways, I have 241,000 on my ZJ. Motor has never been opened up (at all) and the tranny is original.
Smokes a little under hard accelleration of it I let it idle too long, but otherwise it's fine, and I beat the piss out of it!
98 Jeep GC 5.9 - Mopar intake, Mopar ECU, Edelbrock struts, lots of audio (see details)
89 MR2 MK1.5 - Body done, built 450whp 3sgte, 6 year project so far
89 MR2 SC - 317k! rims, cams, lsd, pulley, exhaust, intake, header, brakes, stereo, bushings... still going :)
74 CB360 - Lots of cool cafe stuff :D
aaron7 is offline   Reply With Quote
Old 08-14-2008, 01:28 PM   #15
arveetek
My '93 5.2L has 295,000 miles on it, and as far as I know, it's all original. Runs a little rough, but not too bad.
Casey
1997 Wrangler TJ, 2.5L LO, 5 speed, RC 3.25" lift, Skyjacker shocks, 31's, Lock-Right locker in front, Bestop 2-piece Hardtop
arveetek is offline   Reply With Quote
Glock Forum
