Lets talk balljoints & rim backspacing. - JeepForum.com
post #1 of 23 Old 12-01-2014, 04:44 PM Thread Starter
evan1395
So after my alignment the guys at the shop said my axle was slightly tweaked and that OFFSET balljoints would be the best way to get a true front end alignment. Does anyone know if Spicer makes an offset balljoint? I was getting outside tire wear on my front passenger tire.
As for rim backspacing. I was talking with Kg6mov about this subject and he passed on alot of good input. I just installed a IRO 3.5" Benchmark kit and am wanting to fit 32's under it. I heard from alot of JF members that it is possible with the right backspacing on my wheels. What does everybody reccomend and what does everybody currently run with that setup?
J.E.E.P (Just Empty Every Pocket)
evan1395 is offline
post #2 of 23 Old 12-01-2014, 06:39 PM Thread Starter
evan1395
Anyone???
evan1395 is offline
post #3 of 23 Old 12-01-2014, 07:22 PM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
Post up the alignment specs.
HighLonesome is offline
post #4 of 23 Old 12-01-2014, 07:38 PM Thread Starter
evan1395
LEFT FRONT
Camber Before: -0.74
Camber Actual: -0.60
Caster Before: 6.74
Caster Actual: 6.74
Toe Before: 1.27
Toe Actual: 0.13
RIGHT FRONT
Camber Before: 0.72
Camber Actual: 0.65
Caster Before: 6.01
Caster Actual: 6.01
Toe Before: 1.28
Toe Actual: 0.14
FRONT
Cross Camber Before: -1.46
Cross Camber Actual -1.45
Cross Caster Before: 0.74
Cross Caster After: 0.74
Total Toe Before: 2.55
Total Toe Actual: 0.27
evan1395 is offline
post #5 of 23 Old 12-01-2014, 07:40 PM Thread Starter
evan1395
Per Invoice From Shop...
" Truck pulls right camber off right front positive left front is negative. Suggest all four ball joints with the uppers offset for better alignment".
evan1395 is offline
post #6 of 23 Old 12-01-2014, 07:58 PM
Technohead
If the axle really is tweaked it would be cheaper to buy a junkyard replacement than install offset ball joints.
You should be able to run 32's with the stock backspacing and 3 1/2 lift. If you get aftermarket wheels then look for 4" backspacing.
-Eric
Technohead is offline
post #7 of 23 Old 12-01-2014, 10:49 PM Thread Starter
evan1395
Thank you Techno. 4" it is then!
Are offset balljoints spendy? Or is the installation just a pain in the a$$?
evan1395 is offline
post #8 of 23 Old 12-01-2014, 10:56 PM
riot1987
Ive never heard of an "offset'' ball joint before
Build thread^^
riot1987 is offline
post #9 of 23 Old 12-01-2014, 10:57 PM
riot1987
http://www.jegs.com/p/Specialty-Prod...55170/10002/-1
Build thread^^
riot1987 is offline
post #10 of 23 Old 12-01-2014, 11:12 PM Thread Starter
evan1395
Hole-ee CRAP!
$75/PER ball joint? Thats crazy! I bet its still cheaper than what Big O would charge me. However I dont think they install outside products.
And I reallllly dont wanna go chewin up new tires as a result of not getting them.
evan1395 is offline
post #11 of 23 Old 12-02-2014, 03:11 AM Thread Starter
evan1395
15X8" right?
evan1395 is offline
post #12 of 23 Old 12-02-2014, 04:13 AM
PolkaPower
15x8 is all you'll ever need.
PolkaPower is online now
post #13 of 23 Old 12-02-2014, 11:04 AM
kg6mov
Hears the voices
kg6mov's Avatar
Yeh the offset balljoints can correct for the axle being slightly bent but it would be better to get a new one and truss it.
kg6mov is online now
post #14 of 23 Old 12-02-2014, 02:07 PM Thread Starter
evan1395
I wish I had the time for that. I barely got the free day to throw my lift on from the mrs and 18 month old daughter lol.
evan1395 is offline
post #15 of 23 Old 12-03-2014, 12:08 AM
Kolak
Vendor
Kolak's Avatar
Is the shop assuming the axle is bent due to the camber being out of spec?
Or did they inspect the axle and measurements showed it was bent?
Kolak Performance and Offroad
Member: Specialty Equipment Market Association
Telephone: 480 998-3661
or
Kolak is online now
