Lets see if anyone can figure this one out! - JeepForum.com
post #1 of 11 Old 09-25-2009, 11:25 AM Thread Starter
Darmon6669
Ok, im new to jeeps. This problem has been driving me crazy... I have a 1996 Grand Cherokee Larado 4.0L with select trac 4x4, I bought it from a guy that hit a curb hard with the right front wheel. So hard that it pushed the diff into the oil pan wrecking the oil pump and engine. So i bought an engine from a 1991 cherokee with seems to be the identicle block, I installed the engine and a new front diff and the truck runs great! BUT only in park.
I try and shift to reverse and it dies, It will go in drive and neutral fine only if its cold and in drive it will actualy drive fine for about 50 feet and the tranny grabs instantly and feels perfect when its cold and then it stalls, but let everything heat up and it dies instantly as soon as it shifts out of park. I have even tryed reving it to 3000 and going from park to neutral but still dies!!!
My only thought is it needs a new Torque converter or TCM, It seems as soon as its not in park even with out the tranny engaging there is a big load on the engine or some how fuel or ignition is being cut off!!
If anyone has had this problem or any ideas of something im overlooking please help!! Thanks in advance!
Darmon6669 is offline
post #2 of 11 Old 09-25-2009, 12:25 PM
driabyor
driabyor's Avatar
1994 ZJ
did you switch all the electronics from you old engine..
did you force the tranny and engine together.... the convertor has to line up with the pump or it will mess it up..
94 Grand Cherokee ... 332,000 miles
5.2 liter 242 :)
Rancho 5000 steering stabilizer
driabyor is offline
post #3 of 11 Old 09-25-2009, 12:49 PM Thread Starter
Darmon6669
Yup, i took the new engine down to a long block. And i didnt touch the converter at all.
When i bolted the new engine in i tightened everything up and spun the converter with one finger to line the bolt holes up with the flex plate so there should be no problem with the pump.
Thanks for the reply.
post #4 of 11 Old 09-25-2009, 01:06 PM
MarkoPo
MarkoPo's Avatar
2005 WK
I wonder if you are having some sort of problem with the neutral safety switch. Will it start in neutral and park only? Try starting it in gear and see how it acts. Or you could try bypassing the switch and see if that helps.
05 Grand Cherokee Limited 5.7 Hemi
06 pontiac Torrent AWD
96 Grand Cherokee Laredo 4.0 newest edition to the family.
Hemi Club member #2
Bonafide Gun Guru
MarkoPo is offline
post #5 of 11 Old 09-25-2009, 01:14 PM Thread Starter
Darmon6669
Switch is good, only starts in park and neutral but if its hot it wont start in neutral only park.
post #6 of 11 Old 09-25-2009, 01:19 PM
driabyor
driabyor's Avatar
1994 ZJ
you did get the correct front axle...
try disconnecting the front drive shaft... maybe it will run then.. probably a long shot... if it works your buying the beer
5.2 liter 242 :)
driabyor is offline
post #7 of 11 Old 09-25-2009, 01:21 PM
MarkoPo
MarkoPo's Avatar
2005 WK
Starting to sound like there is a problem in the transmission itself. When it gets hot is just quits? Does the engine just stop like you turned the key off or does it sound like it is getting bogged down? I wonder if something in the tranny is getting hot expanding and binding up.
Hemi Club member #2
Bonafide Gun Guru
MarkoPo is offline
post #8 of 11 Old 09-25-2009, 04:20 PM
moparrr07
i would say a new flex plate and torque converter, if its grabing that will make it grab most the time if it got ****eyed, thats why i runs in the neutral gears and not drives
-Black Limited 1998 Jeep ZJ 5.2 nv3550 np242, 35s, lots of other stuff
moparrr07 is offline
post #9 of 11 Old 09-26-2009, 03:33 PM
iluvtruenos
Lockup solenoid?
You've go the 42re tranny. Ask the Dakota guys, they use the same tranny as we do.
My Jeep is a chick magnet with reverse polarity.
2000 WJ, 4.5l, AX15, 242 D60/14b, 5.5" lift front, 7.5" rear. Ford Expedition rear coils, Ram 350 shocks, JKS, IRO Long Arms, cool Badlands flag thingy.
1987 XJ - Gone but not forgotten
iluvtruenos is offline
post #10 of 11 Old 09-26-2009, 04:12 PM
urq2
urq2 is offline
post #11 of 11 Old 09-26-2009, 06:53 PM
simidrm
I had the exact same thing happen to mine as well I even took it to the jeep dealer who was lost so I started swaping out parts and did the whole ign system turned out to be crank sensor,I know that don;t sound right but mine did the same thing ran great in park or drive till it warmed up but no matter what if I went to reverse it died instantly drove me nuts for 2 months but thats what it was and now runs great no prob
simidrm is offline
i just cant figure it out hellopeople123 ZJ Grand Cherokee Forum 5 08-24-2009 10:03 PM
Trying to figure out my new (to me) '02 WJ hallwaypd ZJ Grand Cherokee Forum 7 05-18-2009 03:15 AM
Cant figure out this one....... JGC1993laredo ZJ Grand Cherokee Forum 5 03-23-2009 10:15 PM
Can't Figure it out 4weeln ZJ Grand Cherokee Forum 6 03-07-2005 09:16 PM
Need HELP cant figure this out sup2nrmkiii ZJ Grand Cherokee Forum 1 06-05-2003 12:23 AM
