Left turn signal problem - JeepForum.com
post #1 of 3 Old 03-13-2004, 09:37 PM Thread Starter
shrek2003
A couple of weeks ago my left turn signal stopped working intermittently. Right works fine. I have to quickly turn on the hazards and turn them off, at the same time turning on the left turn in order for it to work. I bought a new flasher, but I really don't think that's the problem. Plus, I can't put my hand on the flasher location. Any suggestions?
shrek2003 is offline
post #2 of 3 Old 03-13-2004, 11:08 PM
KyleM
It sounds like the turn signal flasher to me. I had the same symptoms and that turned out to be the problem. It's located in the fuse panel on the kick panel of the passenger side. To find it, just turn on your blinker and listen for it. If I recall correctly, there are basically two types, a squarish one and a round one. The squarish one was the one my '96 jgc needed. Probably easiest to simply yank it out when you get to the parts store.
KyleM is offline
post #3 of 3 Old 03-14-2004, 08:49 AM
greasefingers
greasefingers's Avatar
1994 ZJ
My flasher relay unit is under the glovebox. Have to remove the glovebox innerds to reach it.
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
Left turn signal stays on Germerican WJ Grand Cherokee Forum 15 06-17-2016 10:44 AM
Left rear turn signal intermittant legerdemain ZJ Grand Cherokee Forum 4 12-06-2011 11:15 PM
Left turn signal MNWJ ZJ Grand Cherokee Forum 6 01-12-2010 07:18 AM
left turn signal on? tylem28 ZJ Grand Cherokee Forum 2 08-28-2008 12:58 PM
Strange Problem with Left Turn Signal LedLaidel ZJ Grand Cherokee Forum 3 08-21-2008 08:26 PM
