Quantcast Left fronts brake makes popping noise - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Left fronts brake makes popping noise
Truck-Lite's New LED Headlamp SeriesRuffstuff Axle Simple Swap Kit!Spartan Lockers FREE SHIPPING Excellent Prices
Old 08-08-2007, 07:51 PM   #1
ZJcrawler45
Ever since i replaced my front axle ujoints and hubs my brakes have been making a strange popping noise that occurs under breaking and happens maybe once every revolution. Its loud and it grinds. It first happened about a month a go, so i took everything apart and put it back togetther and it was fine. Now its back and i dont know why. My mechanic tells me that my caliper is not retracting all the way or something. Could that be it or something else? I think im going to just go get a new caliper because they only cost $20
ZJcrawler45 is offline   Reply With Quote
Old 08-11-2007, 09:16 AM   #2
ZJcrawler45
Also it only does it when stopping below 10mph. If above 10mph the brakes are fine... Another weird thing is that all of a sudden it went away yestarday and my brakes are fine. What could be wrong?
Old 08-11-2007, 09:38 AM   #3
randyszj94
1994 ZJ
mine do that when i put it in reverse and back up slowy then hit the brakes a lil,, they actually make that poppin sound and you can see it rock the tire,
[COLOR="Green"]I misss my Jeep.[/COLOR]
randyszj94 is offline   Reply With Quote
Old 08-12-2007, 08:22 AM   #4
ZJcrawler45
ok now it started again when i went to work today...Nobody have anything 2 say?
Old 08-12-2007, 08:24 AM   #5
randyszj94
1994 ZJ
screw it, just drive it, if somthing breaks then fix it...
Old 08-12-2007, 08:39 AM   #6
rxl
I know you said you replaced them but it sounds like the Ujoint.
I bought "MY JEEP" for my wife
I bought "MY OTHER JEEP" for my daughter [she sold it]
I finally bought one for me
Canadian Jeep Club Member #7
99 GC limited
4.7 Quadradrive
97 TJ Sport
4.0 5 speed
99TJ Sahara
4.0 Auto
Sold to a life of blacktop
94 ZJ Limited
I6 Quadratrac
rxl is offline   Reply With Quote
Old 08-12-2007, 07:31 PM   #7
ZJcrawler45
i dont think it is, I mean they've basically have been on there for about a month and are as tight as they can be. absolutely no play at all and they're perfect. And trust me i know what bad ujoints feel like, before i replace them i was driving on horrible ones that had 0 needle bearings in them for 2 years. I do however believe it has something to do with my caliper. I'm going to replace it tomarrow and hopefully it'll be solved.
Old 08-13-2007, 06:31 AM   #8
PaulWB
Just changed mine
I have a 99 WJ and the garage has just changed the front calipers because the left one was sticking on (it wore out the disc in around 18 months). Garage told me that the dealers said it was a known fault.
PaulWB is offline   Reply With Quote
Glock Forum
