LED's in Overhead - JeepForum.com
post #1 of 7 Old 03-11-2006, 11:16 AM Thread Starter
zjeepin
zjeepin's Avatar
LED's in Overhead
I was just wondering if it's possible to change out the bulbs inside the overhead console to LEDs or a whiter bulb.
Thanks
97 ZJ Chop Top-Buggy 5.2L V8, 249 T-Case
5" Lift, JKS Front and Rear Adj. Trackbars, RE Twin Tube Shocks, RE T-Case Drop, Cut Fenders, Chop Top, Half Doors.
33"x13"x16" Super Swamper TSLs on Black Steelies
Custom Rack, 4 Roof Lights, Roof Back-up Lights
zjeepin is offline
post #2 of 7 Old 03-11-2006, 11:48 AM
SteelBlue_WJ
SteelBlue_WJ's Avatar
find out the bulb number and see if they have LED versions of the bulb. these are becoming more popular and common place nowadays
SteelBlue_WJ is offline
post #3 of 7 Old 03-11-2006, 12:08 PM Thread Starter
zjeepin
zjeepin's Avatar
Is there a good place to shop for LEDs On-line.
zjeepin is offline
post #4 of 7 Old 03-11-2006, 05:08 PM
///BHRpowered
///BHRpowered's Avatar
sweet, a thread for me. Yes it can be done, infact I have changed out al lof them in all my cars, for the zj you will need 44mm bulbs (bulb numbers do not exist in led dome lights, just size) the best place to buy from is www.superlumination.com He's a friend of mine from hidplanet and stocks every single led on the market. I went with the blue, but any color is fine, remember, the more led's the better. oh and btw, be very careful when installing them, they only work 1 way so you need to test, and although leds don't mind vibration being slammed into place can screw them up.
"A dark and bitter chill fills the air. once thriving life wallows away into ash as he slithers past, the very stars themselfs part to make way for his haunting, yet oddly claim arrival. Bhr approaches." - Hatter
"But i have to say, BHR's rants go hand in hand with moring coffee to get my day started - RXL"
Admin -
///BHRpowered is offline
post #5 of 7 Old 03-11-2006, 05:09 PM
///BHRpowered
no direct link, just click on festoon dome bulbs and scroll down to the 44mm 9 led bulbs, those are what you need, crazy output
Admin -
post #6 of 7 Old 03-11-2006, 06:20 PM
5point9Limited
5point9Limited's Avatar
What do you mean that they only work one way? do you have to wire them?? or are they plug-n-play?
I will prolly pick some up.
1997 TJ 4.0, 5 Speed, Stock
Sold: 1998 Grand Cherokee 5.9 Limited
5point9Limited is offline
post #7 of 7 Old 03-11-2006, 06:49 PM
///BHRpowered
they plug right in, but only 1 side is postive and only 1 side is negative, its not like other dome bulbs where you stick them in and go, if you put them in and they don't work, flip them around, then they will work
Admin -
ZJ Interior LED's davymark ZJ Grand Cherokee Forum 5 01-17-2010 12:00 PM
Got my LED's installed!!! BlackbeastZJ ZJ Grand Cherokee Forum 55 11-21-2009 03:12 PM
Went to LED's. Short writeup. H3RESQ ZJ Grand Cherokee Forum 18 01-04-2007 04:18 PM
Trouble with LED's bsm413 ZJ Grand Cherokee Forum 4 03-14-2005 09:20 PM
putting an overhead console in a non-overhead consoled gc gregmondro ZJ Grand Cherokee Forum 0 08-04-2004 02:31 PM
