LED lights rundown for 1996 ZJ 2WD with manual climate control - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > LED lights rundown for 1996 ZJ 2WD with manual climate control
PANDEMIC-USA 50" Double row LED LIGHT BAR!! These thi50" SINGLE ROW PANDEMIC LED Light bar FEATURES 4D OptFS: Wranger BRIGHT License Plate LED! Just $3! Great value
Unread 05-20-2015, 09:28 PM   #1
KiloWatts
KiloWatts's Avatar
There are other threads about this, but I found them tough to interpret, especially since size numbers and names have changed a lot. So, I thought I'd make a fresh post for anyone else looking to change all their lights in this model. I spent way too much in shipping separate (and incorrect) orders, so hopefully this helps people who have the same model as me.
This is a (nearly) complete set for a 1996 ZJ Laredo L6 2WD with manual climate control. For other models, search the threads.
Helpful threads with installation photos:
These don't necessarily pertain directly to a 1996 ZJ 2WD manual climate control, but still helpful.
"How to change dash light on 93-98 ZJ"
"Manual heater control led conversion"
WHAT YOU NEED:
Get 360-degree light coverage whenever possible.
(9) size 194 wedge base bulbs:
(7) size 74 wedge base bulbs:
(2) size 4mm twist-in NEO bulbs:
(3) size 3mm twist-in NEO bulbs:
(5) size 578 bulbs:
(2) size BA15S bulbs:
(3) size 3mm solder component bulbs:
WHERE THEY GO:
Behind dash:
(7) size 194 bulbs for gauges and turn signals
Shifter:
(1) size 194 bulb
Manual Climate Control:
(2) size 74 wedge base bulbs behind gauges
(1) size 4mm twist-in Neo bulb behind AC button
Note 1: There is another 3mm solder component bulb behind the AC button, but it is inaccessible without desoldering some connectors)
Note 2: Some years have a different configuration. See this thread.
Lights/Fog-Lights Panel:
(1) size 3mm twist-in Neo bulb
(1) size 3mm solder component bulb for Fog-Light indicator
Overdrive/Defrost Panel:
(2) size 3mm twist-in Neo bulbs
(2) size 3mm solder component bulbs for OD and Defrost indicators
Key Light:
(1) size 74 wedge base bulb
Glove Box:
(1) size 194 bulb
Floor Lights:
Map Lights:
(5) size 578 bulbs (4 in overhead console and 1 in rear door)
Overhead Trip Computer (step and mph/km):
Note: The twist housings will break when removing them. After inserting new bulbs, just solder the connector back in place.
Cigarette Lighter:
Ashtray:
Door Panel Lights (power window switches):
Unknown! I remember finding a post with a photo though - I'll search around.
1996 4.0 L6 2WD. Exciting.
KiloWatts is offline   Reply With Quote Quick reply to this message
Unread 05-20-2015, 09:59 PM   #2
Raiderland
Awesome post! I'm in the process of doing this and this will save me a ton of headache of going back and forth finding which bulb I need for which socket. Wish you'd have posted it earlier lol.
Does anyone have any before and after pics of LED replacement bulbs? Will it make a difference for the in-dash lights? I.E. CEL, highbeams, blinker signals etc?
Raiderland is offline   Reply With Quote Quick reply to this message
Unread 05-20-2015, 11:22 PM   #3
Uniblurb
Uniblurb's Avatar
Cigar lighter: bulb 53. (see #24, p.8A-114, 94-96 ZJ parts list)
96 4.0 ZJ Laredo, 2004 4.7L WJ Limited, 93 4.0 XJ (spare), 96 4.0 XJ (son's)
-Stalling ZJ? 12 things to check before replacing a sensor; the Dirty Dozen
-Crankshaft position sensor multimeter test. & video of testing.
Uniblurb is online now   Reply With Quote Quick reply to this message
Unread 05-20-2015, 11:26 PM   #4
kg6mov
Hears the voices
kg6mov's Avatar
This isa good write up with pictures: http://www.jeepforum.com/forum/f197/...-98-zj-767865/
1996 ZJ Green Laredo V8, 2.5" OME and Bilsteins, 33's, Holes drilled in the roof.
1998 ZJ Platinum Limited 5.9, Backyard parts fodder
kg6mov is online now   Reply With Quote Quick reply to this message
Unread 05-21-2015, 06:56 AM   #5
KiloWatts
KiloWatts's Avatar
Makes a big difference. Brighter, more even, doesn't have the flicker-ish characteristic of incandescent bulbs. Blinkers use 194 also, and are included in this list. For CEL and high beams, they take smaller bulbs - I don't know which kind, but you can see them here in Cache's photo from his thread (they're the smaller twist-in wedges across the bottom):
If I had to guess, they're size 74, but don't take my word for it.
Unread 05-21-2015, 08:52 AM   #6
KiloWatts
KiloWatts's Avatar
Updated:
Cigarette lighter takes a size 74 bulb.
Ashtray takes size 74 bulb.
Overhead Trip Computer takes two size 74 bulbs.
Unread 06-21-2015, 02:09 AM   #7
montrosepatriot
1996-98 a/c control panel (non auto temp)
those who have a manual control A/C panel in a 96-98 ZJ - there are 3 NEO bulbs - T4 (A/C on/off button) and T5 (illuminated display)
montrosepatriot is offline   Reply With Quote Quick reply to this message
