Leaky - JeepForum.com
post #1 of 11 Old 06-17-2011, 09:26 PM Thread Starter
MStaffin
Leaky
Ok. So I was under my jeep. Lol. Who isnt. I saw a leak were the txase bolts up to the trans. Any idea why it could be leaking? Or what is. is there suppose to be a gasket.
00 WJ Zone4in Clayton longarms and linked rearD30/D35 4.88s 33s locked
MStaffin is offline
post #2 of 11 Old 06-17-2011, 09:38 PM
TallyZJ
It is likely the transmission rear output shaft seal. I did mine last week. Same issue. You gotta remove the t-case, replace the trans rear seal and the front input seal on the t-case.
Both seals are available from most any parts store.
There is a cavity between the t-case and the transmission and it has a drain hole. That is where the leak is coming from. No gasket needed. Just clean it and apply some Ultra Grey RTV and slap it back together after you replace the two seals.
1996 Jeep Grand Cherokee Laredo 4x4 - 4.0L
TallyZJ is offline
post #3 of 11 Old 06-18-2011, 07:48 AM Thread Starter
MStaffin
Ok. How hard is it to do. Also is there a write up on it?
MStaffin is offline
post #4 of 11 Old 06-18-2011, 06:39 PM
TallyZJ
Not hard at all. There is a writeup but I was unable to find it.
You will need:
Jack
Four jack stands
3/8" ratchet and a 10mm, 15mm and 18mm sockets and a 3" extension.
5/16" six point box end wrench (for the drive shaft u-joint straps)
14mm box end wrench
14mm very short (like 3" long) box end wrench
18mm box end wrench
15mm box end wrench
Regular set of pliers (for removing a spring clamp)
Flat tip screwdriver
Hammer
Ultra Grey RTV silicone gasket maker
Transmission rear output shaft seal and t-case input shaft seal
A few quarts of ATF+4 to refill the transmission and the t-case if you lose any fluid
A small container of white grease
Can of non-chlorinated brake cleaner ( to remove the old fluid from the t-case exterior)
To remove the t-case you will need to jack the Jeep up and put safety stands (four of them) under it to get it up off the ground a bit. Remove the rear drive shaft completely and the front drive shaft needs to be disconnected at the t-case.
Put a jack under the end of the transmission just before the t-case and put a little pressure on it. Remove the cross member. Remove the transmission mount. Remove the exhaust hanger bracket.
Unplug the two electrical connectors to the transmission and t-case.
Remove the t-case vent hose.
Detach the 4WD shifter connection at the t-case (just lever the ball socket out of the clip).
Let the jack down slowly and let the transmission and t-case hang as low as possible.
Remove the six 14mm nuts between the transmission and t-case union. The top two nuts will be the hardest to reach (hence the short stubby wrench).
Slide the t-case off the transmission. Its bulky but not too heavy.
Clean up the t-case exterior while its off. Clean the cross member also and get all the dirt out of it.
Remove the seal at the rear of the transmission. Use the hammer and screwdriver to pull the seal out carefully. Do not scratch up the transmission shaft. Fluid will pour out (about three quarts). Once it stops draining, clean the area and dry it as best you can. Lube the seal lip and pack the inside of the seal with white grease to retain the seal lip spring. Tap the seal into place slowly using the hammer. Once it is started properly tap it flush with the opening.
On the t-case, remove the three or four 10mm bolts holding the seal housing collar in place. Clean this of any factory RTV sealer. Note its orientation as there are some passages that need to line up. Remove the old seal with the screwdriver. Again be careful not to scar the shaft.
Clean and dry the area. Install the new seal with the hammer tapping it flush with the opening.
Use the Ultra Grey sealer conservatively on the seal housing mating surface. Use just a small amount and smear the bead smooth on the mating side. Install the seal housing and tighten the 10mm bolts to spec (I don't have the spec torque value).
Reinstall the t-case to the transmission being careful not to damage the seals when you mate the shafts up.
Install everything else in revers of how you removed it.
Let her down off the stands, crank it up and let run to operating temp, put it in neutral and lock the parking brake. Check the transmission fluid. It will be low. Turn off the engine and check the t-case fluid level.
Enjoy leak free transmission and at-case seals!
TallyZJ is offline
post #5 of 11 Old 06-18-2011, 07:17 PM Thread Starter
MStaffin
Nice.right up man. I have rwbuilt this trans. Didnt do the seal though. Oops I should have then. Now I gotta pull half this stuff off.again.
MStaffin is offline
post #6 of 11 Old 06-18-2011, 07:33 PM
TallyZJ
You rebuilt an automatic transmission and you had to ask about a simple t-case removal? If you rebuilt the transmission you already knew how to remove the t-case didn't you? I don't see how you could have done that without removing the t-case.
Properly rebuilding the transmission requires a complete dis-assembly of the internals of the trans and I think some of the retainer rings have to be accessed from the tail section of the trans. I am not sure I want to know what you call a rebuild!!
And to not replace an important seal such as the rear output shaft seal while the trans was out?
I guess I don't understand at all.
TallyZJ is offline
post #7 of 11 Old 06-18-2011, 09:40 PM Thread Starter
MStaffin
No. not this trans. Sorry wasnt clear. I know how to remove. Just didnt know how to do the jeep seals. All.vehicles are diff. I only swapped this one. Got it from a totaled jeep. Anyways,its a great write up and I will be using it this week. Lots of help man. Hopefully it will help others too.
MStaffin is offline
post #8 of 11 Old 06-18-2011, 10:45 PM
TallyZJ
Ah! Man, I was starting to think BS on this post. Glad the writeup helps. It is actually easier than you might think. Getting the two top t-case nuts off is the hardest part.
TallyZJ is offline
post #9 of 11 Old 06-19-2011, 08:27 AM
Foundrydude
Now is a good time to buy a seal remover tool. The cheap kind with 2 curved hooks on the end. It's easy to fight a stubborn seal for 15 minutes with a screwdriver, and the more you fight em the more you gack the seal mounting surface. Good luck
Foundrydude is offline
post #10 of 11 Old 06-19-2011, 10:59 AM Thread Starter
MStaffin
Yea I figured that out. On the ground it would have been easy. I put the t case and trans up as one unit on this truck. That was my mistake.. Ive never swapped a jeep trans. It was fun though. Ill be taking the tcase down this week.
MStaffin is offline
post #11 of 11 Old 06-19-2011, 11:00 AM Thread Starter
MStaffin
I have.the.trans I pulled out on the ground. Ill practice first.
MStaffin is offline
