Leaking Sunroof - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Leaking Sunroof
Warn and Smittybilt Free Shipping OfferNew items recently added to Oconee Offroad15 x 8 Black D-Window Steel Wheels Set of 4
Unread 04-28-2008, 05:52 PM   #1
96jeepman
Leaking Sunroof
Hey Guys I have an aftermarket Sunroof on my limited 96 Grand, that seems to be leaking a lot of water when rains (like standing water). Has anyone had this b4. Could the Sunroof drain not be working, any ideas. Thanks \
Rubicon express 4.5 inch lift. OME nitrous charger shocks. 15x8 craggar soft 8's and 32x11.5r15 bighorns . Elemtal Design Componets, amps and 10 inch subwoofer
96jeepman is offline   Reply With Quote
Unread 04-28-2008, 06:29 PM   #2
WJChris
Thats why. Seals and crappy install/product.
That is very common with aftermarket.
WJChris is offline   Reply With Quote
Unread 04-28-2008, 06:38 PM   #3
Windowsrookie
Not much we can help you with. You'll have to contact the manufacturer of your sunroof for new seals.
2000 Grand Cherokee Laredo 4.7L V8 Quadra-Drive
1987 Wrangler 4.2L
Windowsrookie is offline   Reply With Quote
Unread 04-29-2008, 12:08 AM   #4
tubbyzj
1987 XJ Cherokee
yes this has happen to my 94 zj limited, if its coming from the front here is wat you should do to fix it. take off the sunvisor off pull the head liner down a bit, you will see the drain tube if its a rubber one pull it off from the sunroof, now get a bottle of water put water into your mouth and put the rubber hose the drian to your mouth and blow the water into it and blow into it untll the water comes out from the other end repeat this twice to make sure drian is clean, then reinstalll the drian and go to the next one. the sunroof should have 4 drians one in each coner, hope this helps
tubbyzj is offline   Reply With Quote
Unread 05-11-2008, 10:00 AM   #5
96jeepman
Alright thanks guys. Im gunna go try this out
Unread 05-11-2008, 11:22 AM   #6
the1amradio
Shoulda gone for the faux. http://www.autoblog.com/2007/08/21/d...-sun-shine-in/
the1amradio is offline   Reply With Quote
