Leaking from radiator cap, why? - JeepForum.com
post #1 of 27 Old 09-29-2009, 08:01 AM Thread Starter
WXman
Had a coolant leak coming from the radiator cap. Bought a new cap, still leaks. When it's hot, and I shut the Jeep off, it leaks out from the cap and sometimes does it pretty bad. What's going on?
'92 YJ - heavily modded
'96 ZJ - heavily modded
'05 KJ CRD Limited - 370 lb./ft. from a 4-cylinder and trail ready. Pure awesomeness.
'11 Mango Tango JKU Sport - Mods
'12 Dozer JKU Sport S - 6-speed - ACE rock rails - Max Tow package - Daystar spacers - 33x12.50 Duratracs
WXman is offline
post #2 of 27 Old 09-29-2009, 01:33 PM
SJZ
Victim of Hope & Change
SJZ's Avatar
Location: . . . . . . . . . . . . . . . A shining city upon a hill
As the coolant heats up, pressure in the cooling system increases. When the pressure is greater than the rated pressure marked on the radiator cap, the spring in the cap will compress, and coolant will flow past the cap & into the plastic overflow tank. As the engine cools down, coolant is drawn back from the tank into the radiator.
Check for a leaking joint where the small nipple for the coolant overflow hose goes into the radiator neck, a leaking overflow hose, or dirt where the rubber radiator cap gasket seats onto the radiator neck. Also make sure the overflow hose is not cracked or split.
-Steve
"Those who hammer their guns into plows, will plow for those who do not." -Thomas Jefferson
___________________________________________
'98 ZJ Laredo 5.2 Selec-Trac (249 to 242 swap)
'05 KJ Limited 3.7 Selec-Trac
'94 ZJ Limited 5.2 Q-Trac- sold, after 17 years
'67 International Harvester Scout 800; 345ci V8,T18 4spd, Dana 20 TC
'06 Chrysler 300C SRT8 6.1L
SJZ is offline
post #3 of 27 Old 09-29-2009, 04:36 PM
driabyor
driabyor's Avatar
1994 ZJ
head gasket too maybe
94 Grand Cherokee ... 332,000 miles
5.2 liter 242 :)
Rancho 5000 steering stabilizer
driabyor is offline
post #4 of 27 Old 09-29-2009, 07:27 PM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
get an OEM cap too
HighLonesome is offline
post #5 of 27 Old 09-30-2009, 05:33 AM Thread Starter
WXman
It's not coming from the overflow tube, it's actually running out from the cap itself. This is a new (but non-OEM) radiator, and I have two radiator caps now that both let coolant come out. This radiator was run all Summer long with no trouble...now all the sudden the cap is letting coolant come out.
Could I have air in the system somewhere or what? This is annoying me because it's leaking bad enough to drain the reservoir every other day or so.
WXman is offline
post #6 of 27 Old 09-30-2009, 05:58 AM
cmonson
look at the gasket on the cap. Make sure if is in good condition.
a leak is not caused by air in the system.
maybe the mating surface on the non-mopar rad is not perfectly flat. Inspect it and see. Maybe use a file and make sure your cap will seal properly.
cmonson is offline
post #7 of 27 Old 09-30-2009, 07:31 AM Thread Starter
WXman
OK I'll check it. I think you are right...it's probably the non-OEM radiator "neck" that's the problem.
WXman is offline
post #8 of 27 Old 10-02-2009, 11:07 AM Thread Starter
WXman
OK so the problem is that the detent made onto the neck of the radiator isn't thick enough to pull the cap down hard enough to seal everything off as you tighten the cap. If you press down on the cap with your hand, the leak stops. If you turn the cap so that the tabs are directly on the first detent, it'll hold the cap tight enough to stop the leak also. But if you go ahead and fully turn the cap to the position where it stops, the leak returns.
I guess I need to find a way to make the resting detent on the radiator neck thicker, so that when the cap is turned to that position the tabs will hold the cap down tighter. Any ideas on how to do this? I am brainstorming too.....
WXman is offline
post #9 of 27 Old 10-02-2009, 01:10 PM
HighLonesome
I think I have the same problem on my ZJ. You can bend the tabs on the cap, that will help.
post #10 of 27 Old 10-02-2009, 03:59 PM
cmonson
bend the tabs. also, add another rubber gasket. That shoulf fix it.
cmonson is offline
post #11 of 27 Old 10-02-2009, 05:46 PM Thread Starter
WXman
extra gasket...that's a good idea! any more?
WXman is offline
post #12 of 27 Old 10-02-2009, 07:38 PM
McGR
2007 XK Commander
Your coolant overflow system may be clogged.
McGR is offline
post #13 of 27 Old 10-03-2009, 05:50 AM Thread Starter
WXman
I can blow through the overflow tube. no clogs there.
WXman is offline
post #14 of 27 Old 10-03-2009, 07:45 AM
cmonson
it is your cap. double gasket it and bend the tabs a little.
cmonson is offline
post #15 of 27 Old 10-03-2009, 07:52 PM Thread Starter
WXman
OK I bent the tabs some and it seems to have maybe stopped the leak. Ran it until hot in park and no leaks visible...will find out for sure when I drive it next time.
WXman is offline
*new* radiator, yet still leaking! vba ZJ Grand Cherokee Forum 1 08-18-2009 10:36 AM
Please HELP, Radiator leaking ... arctcatrider ZJ Grand Cherokee Forum 6 04-26-2008 02:36 PM
Busted radiator...now leaking oil?? WTF!! lma1973 ZJ Grand Cherokee Forum 17 07-18-2007 01:29 PM
Radiator leaking at seam? lma1973 ZJ Grand Cherokee Forum 8 06-09-2007 01:40 PM
How to fix leaking Radiator ?!?!?!??! truetuner ZJ Grand Cherokee Forum 7 09-11-2006 08:16 AM
