Leak under the front bumper - JeepForum.com
post #1 of 6 Old 02-10-2013, 02:57 PM Thread Starter
simma
Hi, people
this is my first post on the forum, and my english is not so good so if I made some writing mistake, don't be angry on me.
I own 1998. ZJ,5.2 lit with 97000km
My problem is that I notice some small leak under the front bumper on the right side. I can't determine is it oil leak or cooling liquid leak?
Did anyone had similiar problem with Jeep?
simma is offline
post #2 of 6 Old 02-10-2013, 04:26 PM
hezx
Right side as in passenger..... transmision..... right side as in dirver.... oil, brake, or coolant, maybe window wash?
What color is it?
hezx is offline
post #3 of 6 Old 02-11-2013, 03:26 PM
alivenkickin28
your cooler lines go through on the passenger side (right) of the radiator. You have quick disconnect lines there so you are either leaking transmission fluid or coolant.
1995 JGC Limited 5.2 v8, black with gold trim
1976 Olds 98, 82 Olds 98, 84 Olds 98, 89 Trans AM
alivenkickin28 is offline
post #4 of 6 Old 02-11-2013, 05:44 PM
LouC
2007 WK
I don't think that 98s had quick disconnect lines (mine does not) but that rubber line that goes into the bottom fitting on the trans cooler can leak and you will get trans oil right under the bumper. What color is the liquid? Trans oil=reddish color. Antifreeze used to be green now a days can be almost anything depending on what was used....
2007 WK Limited Hemi QDII
1998 ZJ Laredo 4.0 Selectrac
LouC is offline
post #5 of 6 Old 03-29-2013, 03:20 PM Thread Starter
simma
Thank you for all suggestion. Problem solved, it was transmission oil leak because of loss the connection on rubber pipe. Problem was sold without cost and show up because during the winter, rubber parts became harder then usual - my mechanic explanation
simma is offline
post #6 of 6 Old 03-29-2013, 04:42 PM
LouC
2007 WK
The original clamps are spring clips that can lose their tension over time, I had the same leak and solved it with a screw clamp.
LouC is offline
