Leak detection pump - JeepForum.com
post #1 of 2 Old 04-24-2009, 01:51 PM Thread Starter
Y2KGCLIM
Leak detection pump
Well, i finally gave in and took my Jeep to do a smoke test to find out where the leak in my emmision control system was. From what they said it's the leak detection pump. I tried searching the forum, but couldn't find much. Anyone have to replace one? How difficult was it, and how much did it cost? One more question, could that be a reason for my terrible gas mileage? Any help is appreciated, as always!
1999 Steel Blue XJ Sport. 4.0L 4x4. 4.5" IRO Long Arm Lift. 265/65/R16 DuraTracs on 16" ProComp Alloys
2004 Acura TL 6-Speed M/T Navigation. Stock. DD.
2000 WJ Limited 4.7 QD. SOLD
Y2KGCLIM is offline
post #2 of 2 Old 08-12-2009, 06:32 AM
wjcando
I found one that looked pretty new at a salvage yard. On a wj, that sucker is squeezed between the left headlight and the airbox. It was easy to get out of the donor because bumper, grill and other stuff were already gone.
Factory svc manual says the unit is removed/reinstalled by removing only the airbox first. Did that, plus pulled the headlamp out, plus my rig has no fender liners or washer bottle to get in the way. Even then, it was a PITA to remove the old one (using vise grips on the wrong side of the bolt, where the threads extend into the wheel well).
I've only been able to put back two of the three bolts (8mm hex head). The space is so tight, I just can't get to the bottom bolt. Anybody done this replacement before? If so, got any suggestions on technique and tool?
Frank "it-takes-a-village-to-wheel-a-WJ"
McLean, VA
wjcando is offline
Leak Detection Pump P1495 LDP AzSun ZJ Grand Cherokee Forum 15 01-19-2017 02:39 AM
leak detection pump part number tpirocz ZJ Grand Cherokee Forum 4 06-13-2012 05:13 PM
Leak Detection Pump Switch vagator ZJ Grand Cherokee Forum 0 01-02-2007 05:43 PM
Leak Detection Pump(Reply Fast) DMiester129 ZJ Grand Cherokee Forum 2 09-26-2006 04:57 PM
help with code P-1494- leak detection pump askoop ZJ Grand Cherokee Forum 2 07-24-2006 10:32 AM
