leak around oil level sensor - JeepForum.com
post #1 of 8 Old 12-09-2004, 10:18 AM Thread Starter
sightdev
5.2; Leaking around the oil sensor (level sensor) mounted on the side of the oil pan. From the Consumer guide this is apparently a common problem on earlier 5.2 where the oil leaks around the sensor and wall of the pan. I am not due for another oil change for 3000miles so I donít want to take it apart now but will do that later at the next change. I was wondering where the leak is and if I can just tighten the sensor to stop the leak. Is there o-ring that needs replacing or do I need to replace the whole unit? I think I am loosing about few drops a day so it doesnít require immediate attention, but I would like to prepare for permanent fix. Thanks for you input.
sightdev is offline
post #2 of 8 Old 08-20-2012, 08:12 PM
leechiu
Hi I know this was a while ago but how did you fix it? I noticed my 93 ZJ is doing the same thing.
leechiu is offline
post #3 of 8 Old 08-21-2012, 12:13 AM
KoreaZJ
1994 ZJ
How about one of... THESE
Mopar J3243136
(verify prior to purchase)
KoreaZJ is offline
post #4 of 8 Old 08-21-2012, 06:55 PM
dusterdude
Hell,any auto parts store sells that
dusterdude is offline
post #5 of 8 Old 08-22-2012, 08:03 AM
leechiu
Thanks guys. I dont think that will work, it looks like a banjo bolt gasket. This sensor is about 1-1/4" or 1-1/2" in size. I think the only way to fix is to change the whole sensor. I might try to tighten it but afraid it might turn from a seep to a leak!
leechiu is offline
post #6 of 8 Old 08-22-2012, 09:01 AM
gearheadnick
Try teflon tape
My cylinder head overhaul:
My transmission overhaul: http://www.jeepforum.com/forum/f13/how-change-transmission-electronics-1560948/
gearheadnick is offline
post #7 of 8 Old 08-22-2012, 03:54 PM
MN59ZJ
I wouldn't use Teflon tape just because bits of tape may break off into the oil passages. A little bit of thread sealer paste would work though.
MN59ZJ is offline
post #8 of 8 Old 03-27-2013, 09:47 PM
leechiu
Has anyone removed the sensor and plugged the hole? If so what did you use?
leechiu is offline
oil leaking from oil level sensor jeepunlimited ZJ Grand Cherokee Forum 6 02-09-2011 08:12 AM
Oil Level Sensor? Killer Cougar ZJ Grand Cherokee Forum 2 04-04-2008 07:22 AM
Oil Level Sensor trailboy ZJ Grand Cherokee Forum 1 01-16-2007 05:11 AM
oil level sensor bonemover ZJ Grand Cherokee Forum 1 08-30-2006 08:17 PM
Oil level sensor question (ZJ) snowboarder61 ZJ Grand Cherokee Forum 7 12-01-2004 09:15 AM
