in/lbs on torque wrench - JeepForum.com
post #1 of 19 Old 05-18-2009, 02:18 PM Thread Starter
chrisstromberg
I just went and borrowed a torque wrench from autozone for some transmission service I'll be doing tomorrow (first time). The wrench is in ft/lbs, which is perfect for my diffs which need 35 ft/lbs, but the service manual says that for the transmission pan I need 144 in/lbs, which comes out to 12 ft/lbs. The lowest setting on the wrench is 25ft/lbs, and the manual says not to go lower then that. Short of finding a second torque wrench that reads lower, what is the easiest way to achieve 12ft/lbs of torque for the transmission pan?
Thanks a bunch
Chris
chrisstromberg is offline
post #2 of 19 Old 05-18-2009, 02:18 PM
xJoshxx
2012 WK
Thanks a bunch
Chris
going back and getting a In/lb trust me ull want it.
Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 ORA2 sold
2012 WK2 SRT8 - Current
99 WJ Limited Lifted.
2001 WJ stock 4.0 304k miles
xJoshxx is offline
post #3 of 19 Old 05-18-2009, 02:23 PM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
If you have a harbor freight around there, they sell cheap torque wrenches.
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #4 of 19 Old 05-18-2009, 02:54 PM
ZeeJay1997
For info only
Torque wrenches are more accurate at the middle of the scale.
To be more accurate, exercise the torque wrench at full scale 6 times before setting the desired torque reading.
ZeeJay1997 is offline
post #5 of 19 Old 05-18-2009, 03:23 PM
jack9580
2014 WK
You will need a smaller torque wrench. I have 4 different torque wrenchs at work that overlap alot so I can always be in the middle of the torque range since that is where they are most accurate. I would also find a smaller one to do the diffs. I would find on that did say 5-50 ft lbs if I had to have 1 to do both bolts.
2014 WKII Summit (Let the madness begin)
2004 WJ Freedom Edition w/4.7 H.O. heavily modded. Best car ever!!!!!!(sunk + totaled R.I.P. 9/06)
1998 TJ Sahara lifted, locked, and tons of crap bolted on (Sold)
2004 WJ limited w/4.7 H.O. Addco rear bar, JK Rubi wheels. (t-boned and totaled)
jack9580 is offline
post #6 of 19 Old 05-18-2009, 04:25 PM
Bort62
Frankly, for the tranny pan use a 1/4" drive ratchet and tighten the bolts manually. Stop when the torque needed to continue turning exceeds what you can easily supply with a single hand. Too loose = Leak. Too tight = stripped threads. You would have to work pretty hard to strip those threads w/ a 1/4" ratchet about 6" long.
There are many things for which a torque wrench is pretty important (Bearing caps, etc.). For most it is not.
___________
'98 Grand
'60 Ranchero
Bort62 is offline
post #7 of 19 Old 05-18-2009, 04:28 PM
TJineering
get a one foot pipe and apply a 12 lb force at the end of it.
Steve
Jeep - 99 TJ - 2002 4.0
TJineering is offline
post #8 of 19 Old 05-18-2009, 04:45 PM
Bort62
Fish Scale FTW!
___________
'98 Grand
'60 Ranchero
Bort62 is offline
post #9 of 19 Old 05-18-2009, 05:17 PM Thread Starter
chrisstromberg
I picked up a 5-50ft/lbs torque wrench from harbor freight for 20 bucks. That should give me good enough accuracy, right?
post #10 of 19 Old 05-18-2009, 05:21 PM
ZeeJay1997
Chris, that should be good for what you are doing.
Originally Posted by Bort62 View Post
Fish Scale FTW!
Or just tie a 12 lb fish to a one foot pipe.
post #11 of 19 Old 05-18-2009, 05:35 PM
Petee
I was haveing a crappy day till I read this
Thanks.
Petee is offline
post #12 of 19 Old 05-18-2009, 05:59 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
use a 1/4" ratchet or 3/8" and only put your hand over the head of it. give it a 1/8 turn after you get to the point you can't turn it with your hand on the head like that. should be somewhere around 12-18ftlbs according to my calibrated arm.
ratmonkey is offline
post #13 of 19 Old 05-18-2009, 06:20 PM
ZeeJay1997
That's what I was going to suggest but you never can tell if Hercules or PeeWee Herman is going to be on the business end of the ratchet.
post #14 of 19 Old 05-18-2009, 06:50 PM
5-90
5-90's Avatar
1988 XJ Cherokee
I have little "flying saucer" ratchets (disc-shaped ratchets with no handle) that I use for light-duty screws like this. No handle means no leverage, so I can only get it "fingertip tight" and that's it. Since I can't get much grip on the thing (they're lightly knurled,) that effectively limits the torque I can apply.
Saves me digging out my pound-inch torque wrench or torque screwdrivers (the latter were spendy as all get out!)
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
post #15 of 19 Old 05-18-2009, 07:15 PM
Mickey_D
Or if I'd seen this earlier I would have asked the OP if he was in the SLC vicinity of Utah. I've got three torque wrenches of different values.
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
#4
Mickey_D is offline
Torque wrench help crm10 ZJ Grand Cherokee Forum 6 06-16-2009 07:28 PM
Fire wrench to a track bar? psychoworks ZJ Grand Cherokee Forum 8 11-15-2008 12:03 AM
Changing rear pinion seal without inch/pound torque wrench, any experience? shahriarrrr ZJ Grand Cherokee Forum 3 03-15-2008 03:57 PM
Lift and a torque wrench rmtomasin ZJ Grand Cherokee Forum 21 12-19-2007 03:40 PM
Torque Wrench Conversions greasefingers ZJ Grand Cherokee Forum 10 01-01-2006 04:41 PM
