last straw on p0720 error - JeepForum.com
post #1 of 5 Old 08-19-2013, 05:50 PM Thread Starter
bobo49505
Last wed i got a p720 error got the trans speed sensor put it in Friday after my grand Cherokees transmission got possessed the speedometer would go nuts and it couldn't decide what gear it wanted to be in.
So ive changed the trans speed sensor and pig tale , the speed sensor on the t case and pig tale and adjusted the kick down cable.
help what is left that's not in side the trans
bobo49505 is offline
post #2 of 5 Old 08-19-2013, 07:19 PM
ZeeJay1997
0720 is for transmission output sensor. it helps PCM control shift points. the reason you are getting the code is because the PCM is detecting a difference between the transmission sensor and a the vehicle speed sensor which the PCM reads to control the speedometer... that is going nuts on you.
time to chase a new problem. if you have 4wd, the VSS is on the transfer case.
Edit: I just noticed you already changed it. Check and clean PCM connections
ZeeJay1997 is offline
post #3 of 5 Old 08-19-2013, 08:13 PM Thread Starter
bobo49505
ok ill try that in the morning
post #4 of 5 Old 08-20-2013, 06:25 PM Thread Starter
bobo49505
well that dident work and its at the trans shop now
post #5 of 5 Old 08-21-2013, 04:56 PM Thread Starter
bobo49505
Back from the trans shop and i got REALLY lucky a wire on top of the trans had rubbed thru and was grounding on the case. cost $113 all labor
