Last core question. i promise. - JeepForum.com
post #1 of 11 Old 08-08-2008, 09:10 PM Thread Starter
Derek33
Derek33's Avatar
Got the evap core and new accumulator install finished up.
Heat works fine, AC was warm. Tried charging it, and after 2 or 3 cans its still warms.
Anything i need to do differently? Anything i need to do with the accumulator?
Derek
Derek33 is offline
post #2 of 11 Old 08-08-2008, 10:42 PM
kentman
kentman's Avatar
2006 XK Commander
Sure that your compressor and/or compressor clutch are good? I would have a shop try to pull a vacuum to see if it will hold. If not, then something is still leaking. Could be the seals at the compressor.
'06 XK Limited, 5.7L, QD II, Black, 163K
'02 WJ Overland, 4.7L HO, QD, Inferno Red, 126K
kentman is offline
post #3 of 11 Old 08-08-2008, 11:50 PM
SJZ
Victim of Hope & Change
SJZ's Avatar
Location: . . . . . . . . . . . . . . . A shining city upon a hill
Derek
You did evacuate the system, didn't you? System should take 28oz from a vacuum.
There is nothing specific you have to do with the accumulator. Is it possible that you didn't hook up a blend door properly, or left a vac line or wire connection off. When you first start & the engine is still cold, will the AC blow cold then, if so, but blows warm when the engine is hot, that would be indicative of a blend door not working properly. You could always pinch off a heater hose to test, also.
-Steve
"Those who hammer their guns into plows, will plow for those who do not." -Thomas Jefferson
___________________________________________
'98 ZJ Laredo 5.2 Selec-Trac (249 to 242 swap)
'05 KJ Limited 3.7 Selec-Trac
'94 ZJ Limited 5.2 Q-Trac- sold, after 17 years
'67 International Harvester Scout 800; 345ci V8,T18 4spd, Dana 20 TC
'06 Chrysler 300C SRT8 6.1L
SJZ is offline
post #4 of 11 Old 08-09-2008, 04:10 AM
QuadraTokn
QuadraTokn's Avatar
1930 WJ
evacuate first. and you ran dye in the system right?
NEW Dana 44a Axle Truss and Skid !
WJ Grand Cherokee Tube Doors For Sale !
ZJ Grand Cherokee Tube Doors For Sale !
PARTS FOR SALE from 10 WJ Grand Cherokees ! !
QuadraTokn is offline
post #5 of 11 Old 08-09-2008, 08:39 AM Thread Starter
Derek33
Derek33's Avatar
I did none of these, i just recently finished the install.
Whats involved to evacuate the system?
Derek33 is offline
post #6 of 11 Old 08-09-2008, 10:01 AM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
You need a pump to evacuate. Harbor Freight has cheap ones ($10-15) that use shop air.
You need to add PAG100 oil to the new accumulator and evaporator too. I know the accumulator takes 4 ozs.
Is the compressor clutch engaging?
Also, the condensor needs air moving over it to make cold air.
HighLonesome is offline
post #7 of 11 Old 08-09-2008, 10:12 AM Thread Starter
Derek33
Derek33's Avatar
IIRC the clutch was engaging last night when I was trying to charge it.
When you say, I need to ad oil to the evaperator... are you telling me i need to take the evap back out of my dash???
Derek33 is offline
post #8 of 11 Old 08-09-2008, 10:40 AM
HighLonesome
Yes.
No, j/k. But you should add around 6 ozs of oil to the system so the compressor will be lubed properly. Whenever you replace an AC component, you need to add the correct amount of oil to system for that component. The amounts are listed in the FSM.
You will need to evacuate the system for sure. It's full of air and moisture right now.
post #9 of 11 Old 08-09-2008, 04:00 PM Thread Starter
Derek33
Derek33's Avatar
Thanks for the help.
I have to be a pain again and ask for more info about which oil, how much, and where to put it.
I don't have an FSM, I just used my Haynes for everything. Apparently Haynes wont cover this since its "dangerous"
Derek33 is offline
post #10 of 11 Old 08-09-2008, 05:49 PM Thread Starter
Derek33
Derek33's Avatar
this the only oil i need?
http://www.jeepair.com/air-condition...ag-46-1973.php
where do i put it in the system?
Derek33 is offline
post #11 of 11 Old 08-09-2008, 05:54 PM
SJZ
SJZ's Avatar
Check your PMs.
-Steve
SJZ is offline
Another evap core question Derek33 ZJ Grand Cherokee Forum 3 08-01-2008 05:12 PM
one last driveshaft question, i promise.. lakailimited06 ZJ Grand Cherokee Forum 3 07-04-2008 12:57 PM
keeping my promise Derek33 ZJ Grand Cherokee Forum 6 04-19-2008 10:25 PM
New here... heater core question veedubin ZJ Grand Cherokee Forum 2 12-17-2007 11:12 PM
Evaporator Core Question pjkatz04 ZJ Grand Cherokee Forum 3 04-25-2007 02:53 PM
