Laredo overheating - please help - JeepForum.com
post #1 of 8 Old 03-23-2013, 07:04 PM Thread Starter
suey3b
My son has a 2001 Jeep GC Laredo. It started to overhear about a month ago, and we've changed out the thermostat, relay and burned out radiator fan motor, along with the fuse. Nothing has worked. Today we checked that the relay and fan were pulling the correct amperage and were grounded - everything checked out ok. My father in law says it might be the PCM. Which is going to su*k if we have to replace that. How can I check to see if the PCM is bad? Thank you!!
suey3b is offline
post #2 of 8 Old 03-23-2013, 07:09 PM
RTLee
Is the fan not turning on?
Is the cooling system free of leaks? Can you feel heat from both upper and lower rad hoses? Has it previously overheated badly? (if so you may have to block test it for combustion gasses in the cooling system, if this is positive, you have a blown head gasket.)
More info, please!
RTLee is offline
post #3 of 8 Old 03-23-2013, 07:17 PM Thread Starter
suey3b
The fan is not turning on at all, but does when you jump it right from the battery. Checked the amps that it's pulling and it seems to be fine. Relay clicks on and off. Fan does not turn on. It has overheated to the point where it was boiling. As long as he's moving, it's ok. But when it's idling, it overheats.
suey3b is offline
post #4 of 8 Old 03-23-2013, 07:18 PM Thread Starter
suey3b
No leaks in cooling system and it has heat in both hoses.
suey3b is offline
post #5 of 8 Old 03-23-2013, 07:25 PM
RTLee
Was the relay behind the headlight changed as well?
You can check the PCM by activating the fan through a scan tool.
RTLee is offline
post #6 of 8 Old 03-23-2013, 07:44 PM Thread Starter
suey3b
Yes, we changed the relay behind the headlight. Someone had apparently done so in the past, as there was already an access hole cut in the plastic.
suey3b is offline
post #7 of 8 Old 03-23-2013, 07:48 PM
RTLee
It doesn't make sense. At all. The relay is putting out the correct amperage yet isn't turning on? Wiring? Are you actually getting voltage and amperage at the plug ON THE FAN? If so it should turn on...
Real head scratcher here...might be worth getting a shop involved. It's worth it to stop throwing money at the issue.
RTLee is offline
post #8 of 8 Old 03-23-2013, 08:00 PM Thread Starter
suey3b
We checked to see how much amperage the fan was pulling, but now that you mention it, I'm not sure we checked the wires from the relay to the fan connector. I really appreciate the comments and suggestions. I think we're probably going to take it to the shop this week. Thank you.
suey3b is offline
