Labor cost of replacing Bank 1 Sensor 1 OS - JeepForum.com
post #1 of 16 Old 12-08-2008, 10:55 AM Thread Starter
jeepingtom
I took a look at the location of the OS and I don't think I can replace it myself. How much should it cost to have it replaced?
jeepingtom is offline
post #2 of 16 Old 12-08-2008, 11:07 AM
micifus
Original GC'er
micifus's Avatar
What year jeep do you have? Should take less then an hour. Be sure to purchase the tool to remove it, makes life much easier. Also dont by a bosch after market one make sure you get the OEM from the dealer.
- OME Springs - 30"x9.5" Yokohamma's A/T-S -RE Shocks - JKS Quicker Disconnects - FM70 - E-Fan Conversion - 249->242 Swap -
32"x11.5" BFG A/T
4" Lift
"For every one thing I fix two things break"
micifus is offline
post #3 of 16 Old 12-08-2008, 11:19 AM Thread Starter
jeepingtom
I can now reach it, but can a regular wrench tool remove it? Why they bother making a OS tool specifically for it? I already have the Bosch for $25, next time I'll buy Mopar. I want to go head and replace it now.
post #4 of 16 Old 12-08-2008, 11:28 AM
-Joe-
-Joe-'s Avatar
I have always used an adjustable wrench on them..
I also have used bosch without problem.. Just get the one made for your application and not the one you have to wire up yourself. I am not knocking mopar parts, but I have not had a non-mopar part other then a seal cause me problems. But why pay more when you dont have to. At this point I doubt I have many mopar parts on my jeep. (TPS, IAC, temp sensors, o2 sensor, are all aftermarket parts..)
- Joe -
'95 Jeep Grand Cherokee Laredo I6 4.0L
242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs
Moog Cargo Control Springs
Magnaflow Converter - Dynomax Muffler
235/75/15 AT Uniroyal Liberator Tires
-Joe- is offline
post #5 of 16 Old 12-08-2008, 01:44 PM Thread Starter
jeepingtom
i used an adjustable drop forge wrench and replaced the OS. Few days ago, diagnostics said it was OS bank1 sensor1. Now replaced, But the Check Engine light is still on. Must be another dang problem somewhere else.
This jeep gives so many check engine lights and I haven't had the jeep a year yet.
post #6 of 16 Old 12-08-2008, 01:55 PM
Tony89
does whatever diagnostic tool you are using give you any more detail? a lot of the time it will give an OS code with a "heater" description of some sort which turns out just to be a fuse.
Tony89 is offline
post #7 of 16 Old 12-08-2008, 03:39 PM Thread Starter
jeepingtom
i had advanceauto test again after os change, the code produced was the same p0135 os heater malfunction bank 1 sensor 1
i will look into the fuse thing
post #8 of 16 Old 12-08-2008, 06:56 PM
xJoshxx
2012 WK
pipe wrench small mini mallet mine was rust welded
all fails cut the cords knock the sensor off it and put a socket on it
xJoshxx is offline
post #9 of 16 Old 12-08-2008, 07:31 PM
sadass
I did not know they made a O2 removal tool. I had to do a Search. If this is it, it looks like just like a spark plug Socket . this is it, correct? Id Like to add It to my tool box . I am of the school , work smarter not harder. Nothing better then having the right tool for the Job.
5NineZJ,35mtr/k IRO 7" LA F/R Detroit F/HP-4.56 R/Aussie 44A. ARB Snorkel/JRC Sliders/ Protofab w/9500S./Bushwhackers. Novak242 TCcable.
sadass is offline
post #10 of 16 Old 01-11-2010, 07:49 AM
GenesisGirl
I believe a 1" wrench and 10 min did the trick for mine.
GenesisGirl is offline
post #11 of 16 Old 01-11-2010, 07:59 AM
xJoshxx
2012 WK
2 year bump nice.
Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 ORA2 sold
2012 WK2 SRT8 - Current
99 WJ Limited Lifted.
2001 WJ stock 4.0 304k miles
xJoshxx is offline
post #12 of 16 Old 01-11-2010, 08:02 AM
GenesisGirl
Originally Posted by xJoshxx View Post
2 year bump nice.
??? not sure what you mean???
post #13 of 16 Old 01-11-2010, 09:09 AM
bg00gt
diggin up bones i think is what he means
bg00gt is offline
post #14 of 16 Old 01-11-2010, 09:32 AM
TrdLtly
1983 CJ7
Spelled out: the original post date was Dec of 2008.
1983 CJ7 Daily Driver
SOLD----- 2004 Onyx Green Pearl JGC (WJ) Laredo - 4.0L - SelecTrac - 2" BB - Gal 1:6-9, Mk 13:22-23
TrdLtly is offline
post #15 of 16 Old 01-11-2010, 10:32 AM
GenesisGirl
lol... my bad. a little sleep deprived today
code p0138 bank one sensor 2 leechris ZJ Grand Cherokee Forum 3 01-13-2010 10:08 PM
Bank 1 Sensor 2 '01 Grd Cher o2 sensor location mgrean ZJ Grand Cherokee Forum 15 02-06-2009 12:41 PM
Average labor cost to install lift kit? Rev. Al WK Grand Cherokee & XK Commander Forum 16 08-08-2008 07:06 AM
labor cost for front axle seal... MWR ZJ Grand Cherokee Forum 8 08-29-2005 07:41 PM
Labor cost on engine swap? Rock1127 ZJ Grand Cherokee Forum 14 07-05-2005 08:05 PM
