L-R rear tire tread depth difference -- will this hurt the limited slip diff? - JeepForum.com
post #1 of 10 Old 05-18-2006, 11:30 AM Thread Starter
jo8243
One of my rear tires has 6/32" tread depth left. The other has 9/32" depth left. This happened because one tire was damaged and had to be replaced.
I have a limited slip rear diff on my '02 WJ 2WD. Will this hurt the diff due to the difference in rolling diameters? Or can it handle this much difference?
Thanks
jo8243 is offline
post #2 of 10 Old 05-18-2006, 11:34 AM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
If you have two tires with the same diameter rotate them so the ones that are the same are in the back.
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #3 of 10 Old 05-18-2006, 01:10 PM Thread Starter
jo8243
I don't have two the same size.
Anyone know the answer?
jo8243 is offline
post #4 of 10 Old 05-18-2006, 01:16 PM
ArloGuthroJeep
Mr. Hyde!
So you have 4 different tires? None of them are from the same original set? If that is the case do it right and get 3 new tires to match the new one you just put on. With a tire size difference it'll wear down the LSD faster then with equal size tires...
post #5 of 10 Old 05-18-2006, 01:18 PM
Colorado 5.9
Colorado 5.9's Avatar
If it's 2wd I don't think it will hurt anything. Just put the closest 2 tires in the back.
I've never heard of that hurting LSD before. Just the AWD t-cases which you don't have.
ZJ 98 5.9 LTD. Lots of mods. 7" T&T's Long Arm Lift ,BFG KM2"s,35X12.50x16's,4:56's, Vanco brake upgrade, M1intake,Holley52mmTB,MikeLeach Headers,, Arb'ed HP D30,Aussie Locked rear,Procomp MX6 Shocks,Arb front,RearTR bumpers,ECT.ECT.
Colorado 5.9 is offline
post #6 of 10 Old 05-19-2006, 08:31 AM Thread Starter
jo8243
Anyone know if this is true for sure or not?
jo8243 is offline
post #7 of 10 Old 05-21-2006, 09:28 AM Thread Starter
jo8243
Ttt...........
jo8243 is offline
post #8 of 10 Old 05-21-2006, 09:32 AM
Arkansas_WJ
Arkansas_WJ's Avatar
Yeah it is
How did you get lsd on 2wd?
Mitch
2000 WJ Limited - 4.7l, 4x4, pioneer HU w/ ipod interface, upgraded front calipers, yakima lowrider system, uniden cb w/ 4 ft firestick, 3.5" tweeter upgrade
Arkansas_WJ is offline
post #9 of 10 Old 05-21-2006, 10:25 AM Thread Starter
jo8243
Originally Posted by 02GrandCherokee
Yeah it is
You buy it equipped like that. It was an option, and it didn't matter 2WD/4WD.
So even 3/32" difference will be a problem?
jo8243 is offline
post #10 of 10 Old 05-21-2006, 03:09 PM
rm2001wj
rm2001wj's Avatar
... So even 3/32" difference will be a problem?
That difference is less than 1% in the case of a 28" to 29" tire diameter. Although I can't guarantee that small difference wouldn't matter as far as wear on the LSD is concerned, I would bet that it won't. Tire pressure differences and unequal loading within the vehicle can cause rolling radii differences that large, and I think the LSD was designed to tolerate such differences. Certainly the LSD can tolerate wheel speed differences much larger than that when turning corners or when one wheel is slipping, but of course those differences don't last for a long time.
rm2001wj is offline
need help with switching stock rear diff for a limited slip diff jbearss04 ZJ Grand Cherokee Forum 4 09-02-2010 11:53 AM
Do I have a limited slip diff? eek142 ZJ Grand Cherokee Forum 16 09-22-2009 03:41 PM
rear aussie locker + difference in tire tread = potential problem? the88thpianoman ZJ Grand Cherokee Forum 3 10-06-2008 06:09 AM
Did they put in limited slip or an open diff rear end from the factory? (97 zj 4.0) crmaverick89 ZJ Grand Cherokee Forum 7 10-01-2008 08:37 AM
Limited Slip Rear Diff? nick500ss WK Grand Cherokee & XK Commander Forum 7 04-18-2008 08:09 PM
