KOR Radiator Support won't fit? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > KOR Radiator Support won't fit?
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 09-19-2013, 02:13 AM   #1
zRoxxah
So I'm trying to install this piece, it seemed very easy except it doesn't seem wide enough. Literally off my a mm. I tried forcing it by torqueing the bolts and trying to jack the support into place but no luck. And I don't want to break anything.
I'm guessing this isn't normal?
KOR also forgot to ship my D-Ring shackles too, I'm hoping that's not normal either as this was my 1st purchase from them...
Matte Black '96 ZJ 4.0
IRO 3.5" Benchmark Lift, Bilstein 5100's, 31x10.5x15 Westlake SL369 A/T's, Moog Super Trail Boss SS, KOR Rad Support, Chopped-up Front Bumper
zRoxxah is offline   Reply With Quote Quick reply to this message
Unread 09-19-2013, 06:24 AM   #2
PolkaPower
Posts like these always make me wonder why you didn't call the vendor before posting in a forum. Call KOR and resolve the issue with them. No one here can help you.
PolkaPower is offline   Reply With Quote Quick reply to this message
Unread 09-19-2013, 08:13 AM   #3
Myusername1674
It might actually fit, but it maybe be tight. I had to work with one for a good 30 minutes before as it was so tight. Both sides have to go up at the exact same time or else it won't work.
I would call them about it, but i'm guessing like any company they'll tell you it's the right size and that you should try it again. Do check about your shackles though.
Good luck!
Edit: They may ask for pictures as well for verification, so I'd snap a few maybe measuring the supports length. Might help.
[SIZE="3"]95 FiveTwo ZJ, DD, Lifted, Locked on 35s, [URL="http://alturl.com/d6vk7"][B][COLOR="Blue"]Build[/COLOR][/B][/URL] (in progress)[/SIZE]
[URL="http://alturl.com/22263"][COLOR="Blue"]My 5.9 swap[/COLOR] (in progress)[/URL]
[URL="http://alturl.com/x4ryd"][COLOR="Blue"]Want your zj to be doorless in 60 seconds?[/COLOR][/URL]
Myusername1674 is offline   Reply With Quote Quick reply to this message
Unread 09-19-2013, 09:36 AM   #4
EBrunson
I installed one on my '96 ZJ earlier this year. It will fit with some not so gentle persuasion.
Eddie
1996 Black ZJ 5.2V8 4x4
EBrunson is offline   Reply With Quote Quick reply to this message
Unread 09-19-2013, 10:42 AM   #5
LordHobbit
They are supposed to be tight, but having purchased one that really didn't fit, customer service was awesome and they helped me out a lot. give them a call or shoot an email to them. They will definitely try and help how they can. Let them know that no D-rings were shiipped.
93 red ZJ 190k 4.0. Spent more money than I should have ...
Isn't red the only color a vehicle should be?
If at first you don't succeed, use more speed.
LordHobbit is offline   Reply With Quote Quick reply to this message
Unread 09-19-2013, 12:38 PM   #6
zRoxxah
Good luck!
Just the answer I was looking for. I didn't know whether the part should slip on w/ ease or is super snug like in my case; I didn't want to waste my time. Now that I know it's pretty snug I'll try hammering it on or using a different approach.
Thanks!
P.S. I always loved your buddy icon
Unread 09-27-2013, 12:47 PM   #7
LordHobbit
use a jack, the one that actually fit on mine raised the front end about 4 inches before it slid into place.
