KOR/Kolak H4 Headlight Upgrade *Pic Heavy* - JeepForum.com
post #1 of 12 Old 12-11-2006, 05:47 PM Thread Starter
KingPrat
Well, I did this upgrade a while ago, and I just got around to takin some pics. This is not a write-up, because I didn't feel like tearing the Jeep apart to take pics of everything it entails. Maybe after Xmas.
Relay positioning....notice the plastic bag/duct tape. Keep out that moisture (as to PlatinumZJ's advice)
The housing. Nice glass
The H4 Connector. Each one is grounded to the fender. I ran the wires behind the grille.
Low Beam cutoff. No fogs.
High Beam spread
Low Beams
High Beams
I tried taking some "action" shots, but they just didnt do these babies justice. This upgrade is worth every single penny. A must for every ZJ owner.
New: Steel Blue 2001 Laredo 4.7, QD, Exhaust
Nokian Vatiiva tires: 235/65-17
Previous:1997 ZJ TSi 4.0. Some stuff added
Western New England College '08
Golden Bear Lacrosse #13
Week 11 USILA Rank: #15
2008: 16-5
NCAA Elite 8
TCCC Champions
KingPrat is offline
post #2 of 12 Old 12-12-2006, 06:24 AM
NCJEEPFAN
2006 WK
thanks for the post. how much does it run to do that upgrade?
06 WK Laredo
3.7, 4wd......lift and tires coming soon!
NCJEEPFAN is offline
post #3 of 12 Old 12-12-2006, 06:28 AM
GS Audio
Pics are blocked here at work......gotta remember to check this tonight.
GS Audio is offline
post #4 of 12 Old 12-12-2006, 07:23 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Nicely done.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #5 of 12 Old 12-12-2006, 07:59 AM
Phil Gerard
Former Mod
Phil Gerard's Avatar
It's not cheap - somewhere in the neighborhood of $300 - $400, right? And not really DOT legal, so some Motor Vehicle guy could cause a problem if they were having a bad day. None of this would stop me from doing this mod though!
Nice pics!
Phil
'95 ZJ Ltd. White 4.0L
TW DC DS; ARB Bull Bar, F&R Air Lockers; Superior Axles; Warn Winch; 4.56 gears; ACOS, Addco F&R Sw Bar, JKS Discos, Rr Track Bar & Nerfs, 249>242 Swap, Stillen rotors+Kolak pads, 3 pc. Armor, RE 4.5 Kit + 2.5"BB, Adj. UCAs&LCAs, OME SS, Bilstein 5150s, 15x8 AR Diamond Backs, 33 Truxus MTs, K&N FIPK, RE 62mm TB, Perf. Distr. 4.0L Kit, Exhaust: 2.5" Kolak exhaust FM 70: Optima Yellow, Mean Grn Alt., PIAA 520s, 540s, Kevins Rack, & TB Conversion
Phil Gerard is offline
post #6 of 12 Old 12-12-2006, 11:11 AM
mdsuave13
mdsuave13's Avatar
does this include the new light housings? or is it just for the wiring upgrade?
Safari'd out ZJ.
mdsuave13 is offline
post #7 of 12 Old 12-12-2006, 12:32 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
It is simply amazing what you can find on the internet these days.
This Upgrade consists of:
Two new Glass-lens H4 Headlamp Housings
One High-amperage wiring loom
Two PIAA 80/110w H4 Star White 3800K bulbs*
(*these bulbs do NOT meet DOT guidelines for street usage, but people can and do run them without incident thus far. The glass lenses have a very sharp cutoff so the additional wattage doesn't flood the sky and get in the other drivers' eyes.)
I clicked on the site and scrolled down and clicked again. Being tired, I stopped for a coffee break. Afterwards, I copied and then pasted the information back here. Whew, I'm tired.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.366
post #8 of 12 Old 12-12-2006, 12:33 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Now, I'm really tired.
Are you sick and tired of your "mediocre at best" headlamps on your Jeep? Are your headlamp housing lenses starting to look more yellow than clear? Then this might just be the upgrade for you! We've sourced ZJ headlamp GLASS-lens housing enclosures that accept H4 bulbs rather than the factory 9004 bulbs for a HUGE increase in lighting, particularly noticeable when you're on the backroads at night-time. Additionally, the H4 bulbs have a more sturdy filament design, meaning that they will not burn out as quickly when bouncing around offroad. Another benefit is that your headlamps will now be CLEAR rather than that icky yellow color that the plastic ones turn over time. Next, toss in some brand new PIAA Super-White 110/80w bulbs*, and you are lighting up the night. Lastly, we include a high-amperage wiring harness which will re-route power directly from the battery to the headlamps using a series of relays so that you don't have residual amperage loss by running the wire into the headlamp switch (lots of resistance) and then all the way back to the front of the rig. In essence, you've not only reduced 10' of wire travel, but you've also upgraded the gauge of the wire, allowing far more current to travel to the headlamps, giving you far more light on the road in front of you than the factory left you with. (NOTE: years ago, as an experiment, I spliced a wire into my factory low beam feed and touched it to the positive battery post while the low beam lamps were switched on. I got quite a spark when the wire touched the positive post (bulb needed more amperage than the factory wires can provide) and got probably 20% more light out of that headlamp compared to the other one. So, you'll se a LOT of gain when you add all three upgrades together). Anyway, this is probably a 2 ~ 4 hour job, probably a "3" on the 1-10 scale of difficulty, and requires no prior expertise.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.366
post #9 of 12 Old 12-12-2006, 03:20 PM
Phil Gerard
Former Mod
Hey Hunter you forgot to tell us how much they cost!
Man....hired help these days......
Phil
post #10 of 12 Old 12-12-2006, 05:22 PM Thread Starter
KingPrat
It was $375 shipped to my door, if I remember correctly.
Go easy on Ignignot, Hunter
Oh, and this only took me 1:15-1:30. Longest time was trying to map everything out, where to put the relays, where to run the wires, etc. An extra pair of hands helps too. I'll agree w/ the "3," though.
2008: 16-5
NCAA Elite 8
TCCC Champions
KingPrat is offline
post #11 of 12 Old 12-12-2006, 08:57 PM
Kolak
Vendor
Kolak's Avatar
Excellent photos! I'm still offering the "Power Buy" over in the vendor area. This sale will go on up until Xmas. Check it out here:
http://www.jeepforum.com/forum/f43/euro-zj-headlamp-upgrade-kit-power-buy-333871/
Kolak is offline
post #12 of 12 Old 12-12-2006, 09:19 PM
Arkansas_WJ
Arkansas_WJ's Avatar
The WJers need some powerbuy love too
awesome deal for what you get!
Mitch
2000 WJ Limited - 4.7l, 4x4, pioneer HU w/ ipod interface, upgraded front calipers, yakima lowrider system, uniden cb w/ 4 ft firestick, 3.5" tweeter upgrade
Arkansas_WJ is offline
Kolak headlight small write-up KingPrat ZJ Grand Cherokee Forum 0 11-09-2007 02:48 PM
Kolak WJ brake upgrade Arkansas_WJ ZJ Grand Cherokee Forum 10 04-09-2007 08:40 PM
Kolak Headlight Harness MtnbikerWJ ZJ Grand Cherokee Forum 4 09-21-2005 02:39 PM
Kolak headlight wiring PlatinumZJ ZJ Grand Cherokee Forum 4 08-21-2005 12:03 PM
Kolak Ignition Upgrade Derek33 ZJ Grand Cherokee Forum 1 06-21-2005 03:42 PM
