Kolak has confused me now!!! - JeepForum.com
post #1 of 6 Old 01-25-2005, 02:37 PM Thread Starter
fiddlyD
i emailed kolak about the cat-back exhaust system he sells for my 2001 WJ I-6.
he says i only need the flowmaster and hi-flow cat...and that i dont need the mandrel bent pipes because the OEM ones are already 2.5".
arent the oem pipes restrictive due too that they constrict at points??
fiddlyD
fiddlyD is offline
post #2 of 6 Old 01-25-2005, 02:43 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Are you adding any type of a higher flow intake? If not, the stock exhaust will work just fine.
Hunter
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #3 of 6 Old 01-25-2005, 03:20 PM
DSMjunkie
even if youa re, its not going to make a noticable diff with just an intake nad exhaust...hell even with a header it wont
White Jeep Club Member #982
Air Force Jeep Club Member #16
2k8 JK
1997 nissan stagea drift wagon
1998 legacy wagon grip monster
DSMjunkie is offline
post #4 of 6 Old 01-25-2005, 07:47 PM Thread Starter
fiddlyD
i have the K&N fipk intake.
2001 WJ I-6
fiddlyD
fiddlyD is offline
post #5 of 6 Old 01-26-2005, 01:45 PM
ssimpson6
fiddlyD
The common belief is why replace it if works fine. I went with the FM70 and carsound cat and like it. You can get the mike leach tail pipe but why, your existing tailpipe is just fine.
1979 CJ7 Origional Except for 33 MT BFGs and 2 in lift and 22 gallon tank. (gave to brother)
2000 Cherokee Laredo - Traded in for -
2000 GC Laredo - Tera BB, 245/75/16 BFG ATKOs, Pro Comp MX6, K&N FIPK, Kolak Exhaust, OME SS, Installed factory hooks and hitch, de-ambered all around.
ssimpson6 is offline
post #6 of 6 Old 01-26-2005, 06:37 PM
JCDubya
2009 WK
The tubing foreward of the main converter is 2.5", the tailpipe is 2.25". If I was getting exhaust, i'd try to have it 2.5 (mandrel) all the way through b/c I'm a perfectionist, and I don't like bottlenecks.
JCDubya is offline
Kolak Richtdu89 ZJ Grand Cherokee Forum 30 04-09-2015 10:13 PM
Thanks Kolak!!! avis1055 ZJ Grand Cherokee Forum 31 08-11-2009 06:33 AM
Where is Kolak? IRPerformance ZJ Grand Cherokee Forum 17 08-21-2008 03:06 AM
Kolak Ignition brsox88 ZJ Grand Cherokee Forum 5 10-31-2007 08:23 PM
Kolak wassy ZJ Grand Cherokee Forum 14 12-12-2006 10:18 PM
