Knock in steering on my ZJ - JeepForum.com
post #1 of 7 Old 07-25-2009, 08:44 PM Thread Starter
clmm69
So I bought this jeep with a 3-4" lift. Everything is really nice on it....except.... I get a knocking in my steering. It doesn't happen at lock to lock but some where within 45deg of 0 (straight). Has anyone had this problem. If so what was the problem or solution? Its a 95 Limited 5.2 if that helps any. Thanks..
clmm69 is offline
post #2 of 7 Old 07-25-2009, 08:48 PM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
Look at the trac bar, where it mounts to the front axle.
May seem tight, you won't be able to move it by hand. But it's common for the mount on the axle to oval out, causing a clunk and eventually death wobble.
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #3 of 7 Old 07-28-2009, 08:42 PM Thread Starter
clmm69
ok ill go check... thanks for the info.. although they look and seem tight... there is 2 of them right? i might have to go look again..
clmm69 is offline
post #4 of 7 Old 07-28-2009, 08:59 PM
malibubts
Take a look at the bushings on all of the front linkage. I had this issue with my WJ when turning, almost a clunk sort of noise. It turned out being the tie rod end. I know the linkage is definitely different on the ZJ but check out the bushings.
Eric - '02 Laredo Grand Cherokee
malibubts is offline
post #5 of 7 Old 07-28-2009, 09:14 PM
Kota04SXT
2006 WK
My 94 did that shortly after the lift. Ended up being the front trac bar on the ball joint end.
2013 Ram Express QC 4x4
2006 WK
Kota04SXT is offline
post #6 of 7 Old 07-29-2009, 01:06 AM
0oJeepo0
Replace track bar and look at bushings...may be bad
98' JGC V8 5.2L Limited
3" Kolak Exhaust w/FM 50 SUV, K&N FIPK 57 Series, 245/70/16 Goodyear Fortera TripleTred
0oJeepo0 is offline
post #7 of 7 Old 07-29-2009, 01:22 PM Thread Starter
clmm69
Well I found out what my problem is/was. I backed out of the driveway and I noticed that my tired rubbed on my front bumper while turning. I started driving away and everything was fine.......... So I thought...
I went a little ways and noticed it was not steering right. Took an extra turn or so to just to make a normal left hand turn. So as not being too far from home I attempted to make a u turn (4 point turn) and said wow thats really odd. I got it home by driving 15mph as 25 it started the so called death wobble. Pulled it into my driveway and sure enough. The trac bar, ball joint kingpin snapped right at the frame. Thank goodness I wasn't driving down the freeway.
Any suggestions on new trac bars?
clmm69 is offline
4.7L Knock BlueEvo ZJ Grand Cherokee Forum 3 09-24-2008 10:19 PM
There's a knock under my '96 ZJ! muzicman82 ZJ Grand Cherokee Forum 5 06-10-2008 10:27 AM
Knock knock knock yrubugn ZJ Grand Cherokee Forum 0 06-21-2007 08:26 AM
knock,knock, what the heck is that? paintnjeeps ZJ Grand Cherokee Forum 7 01-14-2005 07:32 PM
Harmonic Balancer Knock Knock Knock eaglewerks ZJ Grand Cherokee Forum 2 01-01-2005 10:11 AM
