"Knock" or "Clunk" coming from my rear right... - JeepForum.com
post #1 of 7 Old 12-24-2010, 03:15 PM Thread Starter
amefford
Whenever I drive over a bump, I hear a clunk or knock coming from my right rear. Ive heard it could be brakes, cat, exhaust hangers, O2 sensor, and heat shields. But, I wanted to know if someone else actually knows what it is? I have the 5.2 V8, I dont think it could be the exhaust, I had the shop recheck the welds on my new pipe, cat, and glass-pack. The cat is still original though...
amefford is offline
post #2 of 7 Old 12-24-2010, 03:40 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
climb under there and look for loose stuff. there is no other way to diagnose a clunk. get to it.
ratmonkey is offline
post #3 of 7 Old 12-25-2010, 03:55 AM
lateralus3
1994 ZJ
i used to have the same noise. it ended up being the tailpipe where it goes up over the axle it was hitting the the trackbar and the gas tank skid
Jacob
1994 grand cherokee laredo 4.0 IRO 5.5 critical path long arm kit and OTK steering 35x12.50x15 BFG KM2's
high pinion dana 30 and 8.8 in garage
FOR SALE ONE SET OF ZJ D44A AXLE SHAFTS $150 SHIPPED
lateralus3 is offline
post #4 of 7 Old 12-25-2010, 08:26 AM
newfieZJ
Shock bushings , or control arm bushings . More details please , is it only noticed on bumps ?
newfieZJ is offline
post #5 of 7 Old 12-26-2010, 10:53 PM
cologc46
cologc46's Avatar
I have the same problem, a right rear clunk noticed only on bumps. I looked over both the shock and control arm bushings, and did not see any problems. My RE super ride control arms are only one season old, so the bushings should be good. I was thinking it is either exhaust or maybe the spring. Maybe I need a new spring isolator between the spring and the frame?
Other ideas?
cologc46 is offline
post #6 of 7 Old 12-27-2010, 03:41 AM
newfieZJ
Other ideas?
The upper RE arms could still be in question . Depending on when they were made , they may have the "bad" bushings that RE has offered free replacement on .
CA bushings's
track bar bushings
shock rubbers
make sure the springs aren't catching on the bump stops
loose parts like exhaust
Not much else back there
newfieZJ is offline
post #7 of 7 Old 12-27-2010, 05:47 PM
cologc46
cologc46's Avatar
Yep, I already had to replace the front upper bushings. Those blew out in less than one season and were definitely from the bad batch of RE rubber bushings. I *had* super ride front uppers, super flex rear uppers. When the front uppers blew out, I got some new rubber bushings, and bought some new flex uppers. I put in the flex uppers first, and find those are just fine for me. I will leave those in there, since front control arms are a major PITA to remove and reinstall.
The rear uppers I installed are ball joint, super flex, type control arms. I looked at all the rubber end bushings and did not see any problems, but then, sometimes a simple visual inspection will not reveal that a bushing is blown out.
Thanks for the list, I will run through all of them and look.
CA bushings's
track bar bushings
shock rubbers
cologc46 is offline
"xenon" or "true white" headlight bulbs .. exist? sanboy ZJ Grand Cherokee Forum 16 10-12-2010 09:23 PM
Another "clunk" thread - ignore the noise? (2004 WJ) JustSomeDude ZJ Grand Cherokee Forum 5 03-30-2009 10:15 AM
2005 WK - "buzzing" coming from rear after initial start --chris-- WK Grand Cherokee & XK Commander Forum 10 03-26-2009 10:38 PM
rear "thud/clunk"?? mtnjam ZJ Grand Cherokee Forum 5 02-21-2008 11:32 PM
"Clunk" from rear axle area JarheadBoom ZJ Grand Cherokee Forum 11 11-20-2007 01:14 PM
